Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Replace a Fan Duct Motor
Ce dont vous avez besoin
    1. How to Replace a Fan Duct Motor, Fan Duct Motor: étape 1, image 1 de 3 How to Replace a Fan Duct Motor, Fan Duct Motor: étape 1, image 2 de 3 How to Replace a Fan Duct Motor, Fan Duct Motor: étape 1, image 3 de 3
      • Unplug the fan duct motor from its power source.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Replace a Fan Duct Motor: étape 2, image 1 de 2 How to Replace a Fan Duct Motor: étape 2, image 2 de 2
      • To remove the cord secure nut from the housing, twist the nut counterclockwise until the screw slides down easily.
      Demander à FixBot
    3. How to Replace a Fan Duct Motor: étape 3, image 1 de 2 How to Replace a Fan Duct Motor: étape 3, image 2 de 2
      • Using a Phillips head screwdriver, undue the screw attached to the green ground wiring. It will now stay disconnected.
      Demander à FixBot
    4. How to Replace a Fan Duct Motor: étape 4, image 1 de 1
      • Using a pair of scissors, carefully clip the zip ties and disconnect the motor from the power cord. You will no longer need a motor or wires attached. Assure a safe place for your power cord is set to the side continued onward.
      Demander à FixBot
    5. How to Replace a Fan Duct Motor: étape 5, image 1 de 3 How to Replace a Fan Duct Motor: étape 5, image 2 de 3 How to Replace a Fan Duct Motor: étape 5, image 3 de 3
      • Undue first two screws on the side of the ductal housing. Remove and set the screw and two locking washers to the side.
      • You will need the screws and locking washers to attach new fan duct motor unless new motor comes with set up.
      Demander à FixBot
    6. How to Replace a Fan Duct Motor: étape 6, image 1 de 1
      • Remove bracket and fan blade from motor. Lift the blade from the duct and set aside.
      Demander à FixBot
A.C Kauffman
Membre depuis le 01/22/26
133 Réputation
1 tutoriel rédigé
Équipe
Rose State College, Team 1-11, Kirkman Spring 2026 Membre de l'équipe Rose State College, Team 1-11, Kirkman Spring 2026
ROSE-KIRKMAN-S26S1G11
1 membre
11 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 33
Total : 131
