Aller au contenu principal
How to Replace a Leaking Set Screw Tub Spout
Ce dont vous avez besoin
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: étape 1, image 1 de 2 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: étape 1, image 2 de 2
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: étape 2, image 1 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 2, image 2 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 2, image 3 de 3
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: étape 3, image 1 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 3, image 2 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 3, image 3 de 3
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: étape 4, image 1 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 4, image 2 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 4, image 3 de 3
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: étape 5, image 1 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 5, image 2 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 5, image 3 de 3
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: étape 6, image 1 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 6, image 2 de 3 How to Replace a Leaking Set Screw Tub Spout: étape 6, image 3 de 3
    • Retighten the set screw using the 5/32" Allen key.
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
2 autres ont terminé cette réparation.
Hadjie Figueroa
Membre depuis le 01/27/21
145 Réputation
1 tutoriel rédigé
Équipe
York University, Team S16-G3, Turner Winter 2021 Membre de l'équipe York University, Team S16-G3, Turner Winter 2021
YORK-TURNER-W21S16G3
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 15
30 derniers jours : 80
Total : 3,974
