Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Replace a Plastic Snap With a Handheld Tool
Ce dont vous avez besoin
    1. How to Replace a Plastic Snap With a Handheld Tool, Snap information: étape 1, image 1 de 2 How to Replace a Plastic Snap With a Handheld Tool, Snap information: étape 1, image 2 de 2
      • A full set of plastic snaps consists of four parts:
      • Two caps
      • One stud
      • One socket
      • When the snap is installed, the socket and stud will lock together, while a cap holds each of them in place from the other side of the fabric.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: étape 2, image 1 de 3 How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: étape 2, image 2 de 3 How to Replace a Plastic Snap With a Handheld Tool, Remove an existing plastic snap: étape 2, image 3 de 3
      • Follow this step if you need to remove an existing plastic snap.
      • Use pliers to crush the plastic snap until it loosens from the fabric.
      • Remove and discard the broken plastic snap pieces.
      • You can't reuse plastic snaps even if they look undamaged.
      Demander à FixBot
    3. How to Replace a Plastic Snap With a Handheld Tool, Clear the fabric hole: étape 3, image 1 de 2 How to Replace a Plastic Snap With a Handheld Tool, Clear the fabric hole: étape 3, image 2 de 2
      • Push the point of an awl through the fabric hole to clear it for the cap.
      Demander à FixBot
    4. How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: étape 4, image 1 de 3 How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: étape 4, image 2 de 3 How to Replace a Plastic Snap With a Handheld Tool, Install the replacement snap: étape 4, image 3 de 3
      • Use your fingers to squeeze a cap pin through the fabric hole.
      Demander à FixBot
    5. How to Replace a Plastic Snap With a Handheld Tool: étape 5, image 1 de 3 How to Replace a Plastic Snap With a Handheld Tool: étape 5, image 2 de 3 How to Replace a Plastic Snap With a Handheld Tool: étape 5, image 3 de 3
      • Place either a stud or a socket on top of the pin.
      • If you can't see the pin after placing the stud or socket, the fabric is too thick for the snap. You'll need a cap with a longer pin.
      Demander à FixBot
    6. How to Replace a Plastic Snap With a Handheld Tool: étape 6, image 1 de 2 How to Replace a Plastic Snap With a Handheld Tool: étape 6, image 2 de 2
      • Make sure the snap is facing the correct side for the clothing item.
      • Center the snap components in the fastener tool. The cap should sit fully in the black die cup.
      Demander à FixBot
    7. How to Replace a Plastic Snap With a Handheld Tool: étape 7, image 1 de 3 How to Replace a Plastic Snap With a Handheld Tool: étape 7, image 2 de 3 How to Replace a Plastic Snap With a Handheld Tool: étape 7, image 3 de 3
      • Firmly squeeze the fastener tool handles. The white rubber head should bulge slightly from the force.
      • Release the handles and remove the tool from the snap.
      Demander à FixBot
    8. How to Replace a Plastic Snap With a Handheld Tool, Check the new snap: étape 8, image 1 de 2 How to Replace a Plastic Snap With a Handheld Tool, Check the new snap: étape 8, image 2 de 2
      • Visually inspect the snap. The center pin should be evenly flattened.
      • Pull on the snap. The snap shouldn't feel loose.
      • If the pin isn't evenly flattened or the snap feels loose, use the fastener tool to compress the snap again. If that doesn't fix it, remove the snap and start again.
      Demander à FixBot
    9. How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: étape 9, image 1 de 3 How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: étape 9, image 2 de 3 How to Replace a Plastic Snap With a Handheld Tool, Install the other half of the set: étape 9, image 3 de 3
      • Repeat the procedure to install the other half of the snap set.
      Demander à FixBot
For more clothing repair guides, click here.
Arthur Shi
Membre depuis le 01/03/18
348 391 Réputation
929 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 90
30 derniers jours : 369
Total : 6,777
