Introduction
This tutorial is to show you how to replace the rear brake cable on a Vector Haro bicycle. Keep in mind some parts and layouts may vary based on bike model and year made.
Ce dont vous avez besoin
Using the smart wrench and socket wrench, remove the nuts that are holding the connector to the old brake line.
After taking apart the connector, slide the screw off the brake line.
Flip bike back right-side-up.
Slide the connector up near the housing holder. About an inch between the connector and holder should be fine.
Using the smart wrench and 10mm socket wrench, tighten the nut so it grips the brake line firmly.
Using wire-cutters, cut the extra cable so only about an inch remains.
Insert the end of the brake cable with a "nub" into the slot on the rear left brake.
Slide the cable onto the slot on the connector.
Slide the other end of the cable into the holder on the right rear brake.
Pull the cable to clamp down the brakes so they almost touch the rim of the wheel.
Tighten the screw so the cable does not come loose.
You now should have a fully function rear brake on your bike.
2 autres ont terminé cette réparation.
Un commentaire
Добар текст са доста слика ево и текст са истом тему https://www.diyany.net/bicycle-cable-rep...
