Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Replace a Rear Brake Cable
Ce dont vous avez besoin
  1. How to Replace a Rear Brake Cable, Rear Brake Cable: étape 1, image 1 de 3 How to Replace a Rear Brake Cable, Rear Brake Cable: étape 1, image 2 de 3 How to Replace a Rear Brake Cable, Rear Brake Cable: étape 1, image 3 de 3
    • Using the smart wrench and socket wrench, remove the nuts that are holding the connector to the old brake line.
    • After taking apart the connector, slide the screw off the brake line.
    • The nut may be difficult to remove if it has not been removed for a while.
    • Keep in mind the order the parts came off the connector. This will make reassembly easier.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Replace a Rear Brake Cable: étape 2, image 1 de 3 How to Replace a Rear Brake Cable: étape 2, image 2 de 3 How to Replace a Rear Brake Cable: étape 2, image 3 de 3
    • Remove the cable housing from its holders.
    • Slide the housing off the brake cable.
    Demander à FixBot
  3. How to Replace a Rear Brake Cable: étape 3, image 1 de 3 How to Replace a Rear Brake Cable: étape 3, image 2 de 3 How to Replace a Rear Brake Cable: étape 3, image 3 de 3
    • Remove the second cable housing from its holder.
    • Unscrew the other end of the housing from the brake.
    • Remove the housing from the cable.
    Demander à FixBot
  4. How to Replace a Rear Brake Cable: étape 4, image 1 de 3 How to Replace a Rear Brake Cable: étape 4, image 2 de 3 How to Replace a Rear Brake Cable: étape 4, image 3 de 3
    • Apply pressure to the brake to reveal the end of the brake cable.
    • Remove the cable from its holder within the brake.
    • Pull the remaining cable through the brake.
    Demander à FixBot
  5. How to Replace a Rear Brake Cable: étape 5, image 1 de 3 How to Replace a Rear Brake Cable: étape 5, image 2 de 3 How to Replace a Rear Brake Cable: étape 5, image 3 de 3
    • Flip your bike to make the brake housing more visible.
    • Insert the new brake cable into the brake housing.
    Demander à FixBot
  6. How to Replace a Rear Brake Cable: étape 6, image 1 de 3 How to Replace a Rear Brake Cable: étape 6, image 2 de 3 How to Replace a Rear Brake Cable: étape 6, image 3 de 3
    • Slide the cable housing onto the new cable.
    • Re-insert the housing back into its holders.
    Demander à FixBot
  7. How to Replace a Rear Brake Cable: étape 7, image 1 de 3 How to Replace a Rear Brake Cable: étape 7, image 2 de 3 How to Replace a Rear Brake Cable: étape 7, image 3 de 3
    • Slide the rear cable housing onto the new brake cable.
    • Re-insert the housing into its holders.
    Demander à FixBot
  8. How to Replace a Rear Brake Cable: étape 8, image 1 de 3 How to Replace a Rear Brake Cable: étape 8, image 2 de 3 How to Replace a Rear Brake Cable: étape 8, image 3 de 3
    • Slide the screw and washer onto the end of the brake cable.
    • Slide the connector of over the screw and tighten the nut and washer on the other end by hand, so it can slide along the brake cable.
    Demander à FixBot
  9. How to Replace a Rear Brake Cable: étape 9, image 1 de 3 How to Replace a Rear Brake Cable: étape 9, image 2 de 3 How to Replace a Rear Brake Cable: étape 9, image 3 de 3
    • Flip bike back right-side-up.
    • Slide the connector up near the housing holder. About an inch between the connector and holder should be fine.
    • Using the smart wrench and 10mm socket wrench, tighten the nut so it grips the brake line firmly.
    • Using wire-cutters, cut the extra cable so only about an inch remains.
    Demander à FixBot
  10. How to Replace a Rear Brake Cable: étape 10, image 1 de 3 How to Replace a Rear Brake Cable: étape 10, image 2 de 3 How to Replace a Rear Brake Cable: étape 10, image 3 de 3
    • You can recycle the old brake cable for this.
    • Insert the end of the brake cable with a "nub" into the slot on the rear left brake.
    • Slide the cable onto the slot on the connector.
    • Slide the other end of the cable into the holder on the right rear brake.
    • Pull the cable to clamp down the brakes so they almost touch the rim of the wheel.
    • Tighten the screw so the cable does not come loose.
    Demander à FixBot
You now should have a fully function rear brake on your bike.
2 autres ont terminé cette réparation.
Jacob Valdez
Membre depuis le 02/24/15
276 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 23-4, Green Winter 2015 Membre de l'équipe Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 membres
19 tutoriels rédigés
1 commentaire de tutoriel
Добар текст са доста слика ево и текст са истом тему https://www.diyany.net/bicycle-cable-rep...
DiY AnY - Réponse Partager
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 31
30 derniers jours : 143
Total : 15,929
