Aller au contenu principal
How to Replace a Tail Light on a Nissan Pathfinder
Ce dont vous avez besoin
  1. How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: étape 1, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: étape 1, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: étape 1, image 3 de 3
    • Insert a flathead screwdriver into the top of the trim cover and gently pry it towards you.
    • Repeat the above step to the bottom of the trim cover.
    • Pull the trim cover off.
    • Set the trim cover aside in a safe place.
  2. How to Replace a Tail Light on a Nissan Pathfinder: étape 2, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 2, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 2, image 3 de 3
    • Remove the two bolts using a 10mm socket and a 1/4" ratchet wrench.
    • Place the wrench on the top bolt and turn counterclockwise until the bolt is entirely off.
    • Repeat the above step to the bottom bolt.
    • Set bolts aside in a safe place.
  3. How to Replace a Tail Light on a Nissan Pathfinder: étape 3, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 3, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 3, image 3 de 3
    • Gently pull on the tail light housing to disengage the friction fasteners from their grommets.
    • Once all fasteners have been disengaged, pull the tail light housing out.
  4. How to Replace a Tail Light on a Nissan Pathfinder: étape 4, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 4, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 4, image 3 de 3
    • Rotate the grey plastic bulb socket 1/4 and turn counterclockwise before pulling it straight out of the housing.
    • Pull the old light bulb straight out of the socket.
  5. How to Replace a Tail Light on a Nissan Pathfinder: étape 5, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 5, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 5, image 3 de 3
    • Push a new 7443 bulb into the socket.
    • Re-insert the socket into the housing and rotate it 1/4 turn clockwise to secure it in place.
  6. How to Replace a Tail Light on a Nissan Pathfinder: étape 6, image 1 de 2 How to Replace a Tail Light on a Nissan Pathfinder: étape 6, image 2 de 2
    • Line up the two metal pegs near the outer edge of the housing with their corresponding plastic grommets on the rear corner of the SUV.
    • Carefully push the tail light housing back into place.
  7. How to Replace a Tail Light on a Nissan Pathfinder: étape 7, image 1 de 2 How to Replace a Tail Light on a Nissan Pathfinder: étape 7, image 2 de 2
    • Spin in the two bolts a few turns by hand to prevent them from falling.
  8. How to Replace a Tail Light on a Nissan Pathfinder: étape 8, image 1 de 2 How to Replace a Tail Light on a Nissan Pathfinder: étape 8, image 2 de 2
    • Tighten the two bolts by turning them clockwise with the 10mm socket and a 1/4" drive ratchet until tight.
    • Avoid over-tightening the bolts to prevent from cracking the plastic inner edge of the tail light housing.
  9. How to Replace a Tail Light on a Nissan Pathfinder: étape 9, image 1 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 9, image 2 de 3 How to Replace a Tail Light on a Nissan Pathfinder: étape 9, image 3 de 3
    • Line up the trim cover and push it back into place over the inner edge of the tail light housing.
Leslie Salazar
Membre depuis le 09/22/23
169 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 22-10, Watkins Fall 2023 Membre de l'équipe Austin Community College, Team 22-10, Watkins Fall 2023
AUSTINCC-WATKINS-F23S22G10
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 23
Total : 165
