Aller au contenu principal
How to Replace a Toilet's Shut-Off Valve
Ce dont vous avez besoin
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: étape 1, image 1 de 2 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: étape 1, image 2 de 2
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: étape 2, image 1 de 2 How to Replace a Toilet's Shut-Off Valve: étape 2, image 2 de 2
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: étape 3, image 1 de 1
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: étape 4, image 1 de 2 How to Replace a Toilet's Shut-Off Valve: étape 4, image 2 de 2
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: étape 5, image 1 de 2 How to Replace a Toilet's Shut-Off Valve: étape 5, image 2 de 2
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: étape 6, image 1 de 2 How to Replace a Toilet's Shut-Off Valve: étape 6, image 2 de 2
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
Ligne d'arrivée
Jayden Scott-Douglas
Membre depuis le 01/08/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G25, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G25, O'Regan Winter 2021
YORK-O'REGAN-W21S1G25
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 75
Total : 3,177
