Aller au contenu principal
How to Replace the Adhesive for Your Motorola Phone
Ce dont vous avez besoin
  1. How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: étape 1, image 1 de 3 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: étape 1, image 2 de 3 How to Replace the Adhesive for Your Motorola Phone, Scrape off the old adhesive: étape 1, image 3 de 3
    • Use the flat end of a spudger or your fingernail to scrape and remove the old adhesive from the phone body and back cover.
    • Pay attention to areas around the cameras and outer edge of the phone. Any remaining chunks will prevent your part from aligning properly.
  2. How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: étape 2, image 1 de 2 How to Replace the Adhesive for Your Motorola Phone, Remove the remaining adhesive: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
    J'achète
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to any remaining adhesive.
    • Use a microfiber cloth to remove the remaining adhesive.
    • If you are having trouble removing the adhesive, apply a few drops of alcohol to the adhesive and scrape it with a spudger.
  3. How to Replace the Adhesive for Your Motorola Phone, Remove the protective film: étape 3, image 1 de 1
    • Remove the clear protective film from the new adhesive.
  4. How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: étape 4, image 1 de 2 How to Replace the Adhesive for Your Motorola Phone, Apply the adhesive: étape 4, image 2 de 2
    • Be very careful during this step! The adhesive is very sticky, and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Before placing the adhesive on the frame, use the cameras to ensure the adhesive's proper alignment.
    • Lay the adhesive on the frame.
    • Press down firmly on the adhesive along the perimeter of the midframe to secure it to the phone.
  5. How to Replace the Adhesive for Your Motorola Phone: étape 5, image 1 de 2 How to Replace the Adhesive for Your Motorola Phone: étape 5, image 2 de 2
    • Grab the blue protective film's pull tab on the top of the phone and pull towards the bottom of the phone.
    • Pull carefully so the adhesive does not separate from the phone.
  6. How to Replace the Adhesive for Your Motorola Phone, Put the back cover on: étape 6, image 1 de 1
    • If your phone has a rear fingerprint sensor, make sure to secure it in its cutout on the back cover before proceeding.
    • Align the back cover over the back of the phone.
    • Press down firmly for one minute along the perimeter of the back cover and camera bezel to secure it with the new adhesive.
Ligne d'arrivée
Spencer Day
Membre depuis le 09/14/22
61 613 Réputation
445 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 077 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 72
Total : 902
