Aller au contenu principal
How to Replace the Arm of Standard Hinge Eyeglasses
Ce dont vous avez besoin
  1. How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: étape 1, image 1 de 2 How to Replace the Arm of Standard Hinge Eyeglasses, Eyeglasses Arm: étape 1, image 2 de 2
    • Remove the screw holding the broken arm by turning it counterclockwise.
  2. How to Replace the Arm of Standard Hinge Eyeglasses: étape 2, image 1 de 1
    • Carefully set the screw aside and discard the broken arm.
  3. How to Replace the Arm of Standard Hinge Eyeglasses: étape 3, image 1 de 1
    • Thoroughly clean the screw and the connecting hinge using the cleaning cloth to remove any dirt or buildup.
  4. How to Replace the Arm of Standard Hinge Eyeglasses: étape 4, image 1 de 2 How to Replace the Arm of Standard Hinge Eyeglasses: étape 4, image 2 de 2
    • Align the joints of the new arm with the joint connected to the frame.
    • The frame joint should be in between the two joints of the arm.
  5. How to Replace the Arm of Standard Hinge Eyeglasses: étape 5, image 1 de 3 How to Replace the Arm of Standard Hinge Eyeglasses: étape 5, image 2 de 3 How to Replace the Arm of Standard Hinge Eyeglasses: étape 5, image 3 de 3
    • Insert the screw in the hinge and lightly tighten by turning the screw clockwise.
    • Make sure all parts are aligned and that the new arm is not angled.
    • You may want to put the glasses on to make sure the arm is positioned properly.
  6. How to Replace the Arm of Standard Hinge Eyeglasses: étape 6, image 1 de 1
    • Once aligned, fully tighten the screw.
    • You may need to make adjustments to the tightness of the arm. Tighten (turn clockwise) or loosen (turn counterclockwise) the screw until you have a comfortable fit.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Mariam
Membre depuis le 01/16/23
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team N-8, Morris Winter 2023 Membre de l'équipe York University, Team N-8, Morris Winter 2023
YORK-MORRIS-W23SNG8
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 49
30 derniers jours : 209
Total : 2,823
