Aller au contenu principal
How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock
Ce dont vous avez besoin
  1. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: étape 1, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: étape 1, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock, Battery: étape 1, image 3 de 3
    • Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Left side
    • Right side
    • Bottom
  2. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 2, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 2, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 2, image 3 de 3
    • Remove the faceplate from the lock mechanism by pulling straight out.
  3. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 3, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 3, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 3, image 3 de 3
    • Remove the battery pack from the lock mechanism by pulling straight up.
  4. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 4, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 4, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 4, image 3 de 3
    • Remove the batteries from the battery pack.
  5. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 5, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 5, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 5, image 3 de 3
    • Insert new batteries into the battery pack.
  6. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 6, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 6, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 6, image 3 de 3
    • Insert the battery pack back into the lock mechanism by pushing straight down.
    • Make sure the label is facing outward.
  7. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 7, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 7, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 7, image 3 de 3
    • Reattach the faceplate to the lock mechanism by pushing straight in.
  8. How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 8, image 1 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 8, image 2 de 3 How to Replace the Batteries in a Kwikset Home Connect 620 Smart Lock: étape 8, image 3 de 3
    • Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
    • Bottom
    • Right side
    • Left side
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
Lis Cinelli
Membre depuis le 09/28/20
376 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 13
30 derniers jours : 56
Total : 240
