Introduction
A leaky water key can make playing difficult and a horn sound strange. Instrument repair professionals can fix leaky water keys, but often times all a water key needs is a new cork—an easy fix you can do at home. Water key corks are inexpensive and available at most music stores and online, but a wine cork cut to the right size will work in a pinch.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Remove the old cork.
Insert a sharp tool, such as one tine of a pair of tweezers or needle-nose forceps, between the cork and the metal edge.
Pry up the cork using the metal edge for leverage.
Repeat this at several points around the cork until the cork comes free.
If your water key still leaks after replacing the cork, it may need to be bent back into place or may need a new spring. See an instrument repair professional or another online guide for help with this.
7 autres ont terminé cette réparation.
2 commentaires de tutoriel
Let me suggest that there is an easier way to a permanent solution for leaky corks - remove the water automatically by installing a JoyKey. No more leaking corks, no moving parts, no sptings or having to manually deal with water.
For more information:
www.thejoykey.com and http://thejoykey.com/wp-content/uploads/...
