Aller au contenu principal
How to Replace the Wheels on an Office Chair
Ce dont vous avez besoin
  1. How to Replace the Wheels on an Office Chair, Removing Casters: étape 1, image 1 de 1
    • Lay the chair down.
    • If the chair is too heavy to turn upside down, have someone help you do it.
  2. How to Replace the Wheels on an Office Chair: étape 2, image 1 de 1
    • Wipe the stem of the caster with a rag or paper towel to remove any dust or debris.
  3. How to Replace the Wheels on an Office Chair: étape 3, image 1 de 3 How to Replace the Wheels on an Office Chair: étape 3, image 2 de 3 How to Replace the Wheels on an Office Chair: étape 3, image 3 de 3
    • Use a flathead screwdriver in between the caster and the base of the chair to pry the wheel out of the socket.
    • Turn the screwdriver gently until the caster starts to move upwards away from the chair.
    • Try rotating the screwdriver at different angles if the caster won't come out.
  4. How to Replace the Wheels on an Office Chair: étape 4, image 1 de 3 How to Replace the Wheels on an Office Chair: étape 4, image 2 de 3 How to Replace the Wheels on an Office Chair: étape 4, image 3 de 3
    • Use a prying tool that is big enough to fit between the caster and over the stem.
    • Gently pull on the caster upwards and it should come off.
  5. How to Replace the Wheels on an Office Chair: étape 5, image 1 de 2 How to Replace the Wheels on an Office Chair: étape 5, image 2 de 2
    • Measure the wheel's height and length.
    • Once you've done that, purchase your new casters.
    • Large casters(about 3"), are more durable and versatile. Twin-wheel casters are usually used in office settings.
  6. How to Replace the Wheels on an Office Chair: étape 6, image 1 de 2 How to Replace the Wheels on an Office Chair: étape 6, image 2 de 2
    • Push the caster's stem into the bottom of chair leg.
    • Install the new casters.
Ligne d'arrivée
Ismail Dhorre
Membre depuis le 01/10/21
160 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G8, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G8, O'Regan Winter 2021
YORK-O'REGAN-W21S1G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 24
30 derniers jours : 97
Total : 5,383
