Aller au contenu principal
How to Reset Your Schlage Connect to Factory Settings
Ce dont vous avez besoin
  1. How to Reset Your Schlage Connect to Factory Settings, How to Reset Your Schlage Connect to Factory Settings: étape 1, image 1 de 1
    • Ensure the latch is retracted (not locked).
  2. How to Reset Your Schlage Connect to Factory Settings: étape 2, image 1 de 1
    • Remove the battery cover by sliding the cover upwards.
  3. How to Reset Your Schlage Connect to Factory Settings: étape 3, image 1 de 2 How to Reset Your Schlage Connect to Factory Settings: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the bottom screw and top screw.
  4. How to Reset Your Schlage Connect to Factory Settings: étape 4, image 1 de 1
    • Carefully remove the device from the door.
  5. How to Reset Your Schlage Connect to Factory Settings: étape 5, image 1 de 1
    • Locate the programming code behind the alarm device.
    • You will need the original factory's preset user code (listed on the back of the device) for Step 12.
  6. How to Reset Your Schlage Connect to Factory Settings: étape 6, image 1 de 3 How to Reset Your Schlage Connect to Factory Settings: étape 6, image 2 de 3 How to Reset Your Schlage Connect to Factory Settings: étape 6, image 3 de 3
    • Reattach the alarm device to the door by screwing the bottom and top screws.
  7. How to Reset Your Schlage Connect to Factory Settings: étape 7, image 1 de 1
    • Disconnect the battery.
  8. How to Reset Your Schlage Connect to Factory Settings: étape 8, image 1 de 1
    • Discharge residual electricity by pressing the exterior Schlage button three times on the keypad.
    • Performing this step ensures that any residual electricity left in the battery is removed.
  9. How to Reset Your Schlage Connect to Factory Settings: étape 9, image 1 de 3 How to Reset Your Schlage Connect to Factory Settings: étape 9, image 2 de 3 How to Reset Your Schlage Connect to Factory Settings: étape 9, image 3 de 3
    • Press the Schlage button and continue pressing while at the same time reconnecting the battery.
    • You should see three green check marks on the lock's face.
  10. How to Reset Your Schlage Connect to Factory Settings: étape 10, image 1 de 2 How to Reset Your Schlage Connect to Factory Settings: étape 10, image 2 de 2
    • Release the button and reattach the battery cover.
  11. How to Reset Your Schlage Connect to Factory Settings: étape 11, image 1 de 1
    • Complete the reset procedure by pressing the Schlage button one time.
  12. How to Reset Your Schlage Connect to Factory Settings: étape 12, image 1 de 1
    • Enter the original factory's preset user code on the keypad.
    • The bolt will move, and the process is complete once the bolt stops moving.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Amy McElroy
Membre depuis le 09/30/22
265 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 80
Total : 756
