Aller au contenu principal
How to perform a Hard Reset on the Nintendo DS Lite
Ce dont vous avez besoin
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: étape 1, image 1 de 1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: étape 2, image 1 de 2 How to perform a Hard Reset on the Nintendo DS Lite: étape 2, image 2 de 2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: étape 3, image 1 de 2 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: étape 3, image 2 de 2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: étape 4, image 1 de 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: étape 4, image 2 de 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: étape 4, image 3 de 3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: étape 5, image 1 de 1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: étape 6, image 1 de 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: étape 6, image 2 de 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: étape 6, image 3 de 3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: étape 7, image 1 de 2 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: étape 7, image 2 de 2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: étape 8, image 1 de 1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
3 autres ont terminé cette réparation.
Artem Ivat
Membre depuis le 02/05/20
2 709 Réputation
12 tutoriels rédigés
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
161 membres
298 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 68
30 derniers jours : 372
Total : 9,520
