Aller au contenu principal
How to Rewire a Lamp
Ce dont vous avez besoin
  1. How to Rewire a Lamp, Cord: étape 1, image 1 de 3 How to Rewire a Lamp, Cord: étape 1, image 2 de 3 How to Rewire a Lamp, Cord: étape 1, image 3 de 3
    • Before starting the process, remove the lamp shade and bulb by hand.
    • Make sure the lamp is unplugged to avoid the risk of electrocution.
  2. How to Rewire a Lamp: étape 2, image 1 de 3 How to Rewire a Lamp: étape 2, image 2 de 3 How to Rewire a Lamp: étape 2, image 3 de 3
    • Loosen the setscrew with the screwdriver so you can unscrew the socket base.
    • Unscrew the socket base from the threaded tube with your hand.
  3. How to Rewire a Lamp: étape 3, image 1 de 3 How to Rewire a Lamp: étape 3, image 2 de 3 How to Rewire a Lamp: étape 3, image 3 de 3
    • With your hand, pry the socket shell out of its base.
    • Remove the socket with your hand and then cut the wires with the wire cutters.
    • The neutral wire connects to the wide plug blade and is distinguished from the hot wire by ribs, color, printing, or indentations in the plastic insulation.
  4. How to Rewire a Lamp: étape 4, image 1 de 2 How to Rewire a Lamp: étape 4, image 2 de 2
    • Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
    • If you pull off any wire strands while stripping, cut back the cord with the Diagonal cutter.
  5. How to Rewire a Lamp: étape 5, image 1 de 3 How to Rewire a Lamp: étape 5, image 2 de 3 How to Rewire a Lamp: étape 5, image 3 de 3
    • By hand, tie an underwriters knot in the cord.
    • Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
    • An underwriter's knot prevents the wires from pulling out of the screw terminals when cord is tugged. ( The entire process of tying an underwriter knot can be done by hand . Form a loop using the first wire. Then, form a loop around the first wire and pass the tail through its loop. The strain on the cable is now taken by the knot.)
  6. How to Rewire a Lamp: étape 6, image 1 de 3 How to Rewire a Lamp: étape 6, image 2 de 3 How to Rewire a Lamp: étape 6, image 3 de 3
    • By hand, pull the excess cord down through the lamp.
    • Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Molly
Membre depuis le 10/20/17
119 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team S1-G4, Adkins Fall 2017 Membre de l'équipe Missouri Western, Team S1-G4, Adkins Fall 2017
MWSU-ADKINS-F17S1G4
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 19
Total : 1,316
