Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Sew a Hole in a Shirt Pocket
Ce dont vous avez besoin
  1. How to Sew a Hole in a Shirt Pocket, How to Sew a Hole in a Shirt Pocket: étape 1, image 1 de 1
    • Find the hole in the pocket.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Sew a Hole in a Shirt Pocket: étape 2, image 1 de 1
    • Take two pins. Insert one pin into the far left edge of the tear.
    • Insert your second pin into the far right edge of the tear.
    • Use extra pins to secure the tear together.
    Demander à FixBot
  3. How to Sew a Hole in a Shirt Pocket: étape 3, image 1 de 1
    • Choose a thread that is similar to the existing shirt color.
    Demander à FixBot
  4. How to Sew a Hole in a Shirt Pocket: étape 4, image 1 de 1
    • Thread a needle with twice the amount of thread the size of your hole.
    Demander à FixBot
  5. How to Sew a Hole in a Shirt Pocket: étape 5, image 1 de 1
    • Start the repair approximately 1/4 inch before the beginning of the hole. Insert the needle from the inside of the lower left edge of the pocket.
    • Then, take the needle across to the top edge of the hole. Insert the needle into the fabric just above the tear.
    • Pull the thread up all the way until it is snug.
    • Do not pull too tight or the fabric will pucker.
    • Repeat the stitch by inserting the needle slightly to the right of your first stitch. Push the needle from the inside of the pocket through the bottom edge of the hole.
    • Cross back up to the top edge again, inserting the needle from the outside of the pocket to the inside.
    Demander à FixBot
  6. How to Sew a Hole in a Shirt Pocket: étape 6, image 1 de 1
    • Continue the whip stitch until you sew 1/4 inch away from the hole.
    Demander à FixBot
  7. How to Sew a Hole in a Shirt Pocket: étape 7, image 1 de 1
    • Pull the thread gently to reduce the visibility of stitches.
    • Rub the fabric to release the surrounding thread tension.
    Demander à FixBot
  8. How to Sew a Hole in a Shirt Pocket: étape 8, image 1 de 1
    • Cut the strand of thread.
    Demander à FixBot
  9. How to Sew a Hole in a Shirt Pocket: étape 9, image 1 de 1
    • Trim excess fabric or loose threads.
    Demander à FixBot
  10. How to Sew a Hole in a Shirt Pocket: étape 10, image 1 de 1
    • Your pocket is repaired and ready to be used again.
    Demander à FixBot
Ligne d'arrivée
Janel Beedle
Membre depuis le 03/08/25
181 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 1-4, Kiser Spring 2025 Membre de l'équipe Colorado Springs, Team 1-4, Kiser Spring 2025
UCCS-KISER-S25S1G4
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 52
Total : 351
