Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Shorten Long Sleeves on a Knit Jacket
Ce dont vous avez besoin
  1. How to Shorten Long Sleeves on a Knit Jacket, Long Knit Sleeves: étape 1, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket, Long Knit Sleeves: étape 1, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket, Long Knit Sleeves: étape 1, image 3 de 3
    • Mark the length you want your sleeve to be, and cut off 1/2 an inch less for wiggle room.
    • Use scissors to cut off the sleeve and excess cloth.
    Demander à FixBot
    Ajouter un commentaire
  2. How to Shorten Long Sleeves on a Knit Jacket: étape 2, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 2, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 2, image 3 de 3
    • Flip the sleeve cuff inside out and align the sleeve with the sleeve cuff.
    • If you’re a beginner, pin the cuff to the sleeve to keep it in place while sewing.
    Demander à FixBot
  3. How to Shorten Long Sleeves on a Knit Jacket: étape 3, image 1 de 2 How to Shorten Long Sleeves on a Knit Jacket: étape 3, image 2 de 2
    • Thread the needle by inserting the thread into the eye (or hole) of the needle.
    • Tie the thread end by creating a loop at the end of the thread, then pulling the end of the thread through the loop and pulling tightly to create a knot.
    Demander à FixBot
  4. How to Shorten Long Sleeves on a Knit Jacket: étape 4, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 4, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 4, image 3 de 3
    • Use a regular stitch to sew the sleeve back on.
    • Insert the needle into the two layers (sleeve and sleeve cuff).
    • Pull the thread all the way. Do the same a centimeter next to the previous stitch, pulling the needle and thread through to the other side.
    • Do the same a centimeter next to the previous stitch, pulling the needle and thread through to the other side.
    • Repeat along the edge of the sleeve cuff.
    Demander à FixBot
  5. How to Shorten Long Sleeves on a Knit Jacket: étape 5, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 5, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 5, image 3 de 3
    • Tie the thread end by creating a loop and pulling the needle through until a knot is formed. Repeat 3 times.
    • Cut the excess thread.
    • You can repeat tying the knot until it is secure.
    Demander à FixBot
  6. How to Shorten Long Sleeves on a Knit Jacket: étape 6, image 1 de 1
    • Thread needle (repeat Step 3).
    Demander à FixBot
  7. How to Shorten Long Sleeves on a Knit Jacket: étape 7, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 7, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 7, image 3 de 3
    • Be careful not to hurt yourself by pulling the needle up and towards you!
    • Use a double thread stitch.
    • Pull the needle upwards until it is halfway through both layers.
    • Loop the thread around the needle before pulling it all the way through.
    • Do the same stitch a centimeter next to it.
    Demander à FixBot
  8. How to Shorten Long Sleeves on a Knit Jacket: étape 8, image 1 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 8, image 2 de 3 How to Shorten Long Sleeves on a Knit Jacket: étape 8, image 3 de 3
    • Tie off thread ends and cut the excess thread (repeat Step 6).
    Demander à FixBot
  9. How to Shorten Long Sleeves on a Knit Jacket: étape 9, image 1 de 1
    • Turn the sleeve inside out, and this is the result!
    Demander à FixBot
Ligne d'arrivée
Helen
Membre depuis le 09/23/25
169 Réputation
1 tutoriel rédigé
Équipe
CSU Sacramento, Team 1-2, Laflen Fall 2025 Membre de l'équipe CSU Sacramento, Team 1-2, Laflen Fall 2025
CSUSAC-LAFLEN-F25S1G2
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 39
Total : 278
