Aller au contenu principal
How to Stabilize the Logitech Harmony 900 Motherboard
Ce dont vous avez besoin
  1. How to Stabilize the Logitech Harmony 900 Motherboard, Battery: étape 1, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard, Battery: étape 1, image 2 de 2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. How to Stabilize the Logitech Harmony 900 Motherboard: étape 2, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 2, image 2 de 2
    • Push the battery in, pull it up, and slide it out.
  3. How to Stabilize the Logitech Harmony 900 Motherboard, Motherboard: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. How to Stabilize the Logitech Harmony 900 Motherboard: étape 4, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 4, image 2 de 2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. How to Stabilize the Logitech Harmony 900 Motherboard: étape 5, image 1 de 1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. How to Stabilize the Logitech Harmony 900 Motherboard: étape 6, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 6, image 2 de 2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. How to Stabilize the Logitech Harmony 900 Motherboard: étape 7, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 7, image 2 de 2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. How to Stabilize the Logitech Harmony 900 Motherboard: étape 8, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 8, image 2 de 2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. How to Stabilize the Logitech Harmony 900 Motherboard: étape 9, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 9, image 2 de 2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. How to Stabilize the Logitech Harmony 900 Motherboard: étape 10, image 1 de 1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
  11. How to Stabilize the Logitech Harmony 900 Motherboard, How to Stabilize the Logitech Harmony 900 Motherboard: étape 11, image 1 de 1
    • Fold a small piece of paper several times until you have a shim about the size of a penny.
  12. How to Stabilize the Logitech Harmony 900 Motherboard: étape 12, image 1 de 2 How to Stabilize the Logitech Harmony 900 Motherboard: étape 12, image 2 de 2
    • Place the shim on the CPU, which is the top leftmost black box on the motherboard.
5 autres ont terminé cette réparation.
Tyler Hanks
Membre depuis le 09/25/17
442 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S4-G5, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S4G5
4 membres
4 tutoriels rédigés
3 commentaires de tutoriel
Bought this remote at Goodwill for $15. Repair went flawlessly in 10 minutes. THANKS!!!!!!
Scott Casey - Réponse
Hello Tyler,
If you are going to place the shims on the top of cpu, why you have to remove the motherboard completely with screws and ribbon cable from the remote?
Thanks
Daniel Leprince - Réponse
Sweet fix thought mine had died
Sean Garbe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 1,393
