Aller au contenu principal
How to Stabilize the Stem of a Longwise ES06 E-Scooter
Ce dont vous avez besoin
  1. How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 1, image 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter, How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 1, image 2 de 2
    • Power off your E-Scooter and make sure it is not charging.
  2. How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 2, image 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 2, image 2 de 2
    • Slide the locking clip out from the base of the stem.
    • Unlock the clamp on the stem.
  3. How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 3, image 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 3, image 2 de 2
    • Gently lower the stem onto the back wheel and keep it stable.
  4. How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 4, image 1 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 4, image 2 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 4, image 3 de 3
    • Using an adjustable wrench, carefully tighten the bolt at the base of the stem.
    • This will make the stem stable.
    • Do not use the wrench on the spring between the stem and the bolt as it may damage the wires beneath.
  5. How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 5, image 1 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 5, image 2 de 3 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 5, image 3 de 3
    • Using a slotted/flathead screwdriver, carefully tighten the screw on the clamp.
    • This will prevent the clamp from popping open.
  6. How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 6, image 1 de 2 How to Stabilize the Stem of a Longwise ES06 E-Scooter: étape 6, image 2 de 2
    • Use a Phillips #0 to tighten the screw on the locking clip.
    • This helps the clamp to stay in place and prevent it from popping open.
Maithili Admane
Membre depuis le 09/24/22
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team B-3, Allen Fall 2022 Membre de l'équipe York University, Team B-3, Allen Fall 2022
YORK-ALLEN-F22SBG3
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 57
Total : 619
