Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If your Mac isn't connected to a storage drive with macOS installed, or your boot drive is corrupted, the computer will flash a question mark folder icon on startup, and then shut down.
Follow this guide to boot your Mac to Internet Recovery mode and access recovery tools like Disk Utility, Time Machine, and the macOS installer.
Internet Recovery is only available on Apple computers made after 2009. If your computer was released in 2010 or 2011, you may need to update to the latest version of macOS and/or perform an EFI and SMC firmware upgrade to enable Internet Recovery.
  1. Shut down the computer.
    • Shut down the computer.
  2. Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
    • Once the computer is completely shut down, press the power button, then immediately press and hold the key combination cmd + option + R.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. When the spinning globe animation appears, you can release the keys. The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
    • When the spinning globe animation appears, you can release the keys.
    • The globe will spin while Internet Recovery starts up. If you are not using a wired internet connection, a choose network prompt will appear. Use this menu to connect the computer to a WiFi network.
  5. Once a network connection has been established, a progress bar will appear underneath the spinning globe.
    • Once a network connection has been established, a progress bar will appear underneath the spinning globe.
  6. When Internet Recovery has loaded, you will see the macOS recovery screen.
    • When Internet Recovery has loaded, you will see the macOS recovery screen.
From the recovery menus, you can restore your data from a Time Machine backup, Reinstall macOS, get help online, and use Disk Utility to format and diagnose problems with any connected storage drives.
2 autre(s) ont terminé cette réparation.
Taylor Dixon
Membre depuis le 26/06/2018
27 435 Réputation
82 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
111 membres
10 674 tutoriels rédigés
15 commentaires
Apparently PowerBook G4 12” does not work for restoral based upon this exercise?
72Yonatan - Réponse
Oh, I’m so sorry! I forgot to specify: internet recovery mode is only available on newer Apple computers. I’ve updated the intro now, sorry for the confusion!
Taylor Dixon -
So a mid 2009 computer won’t have internet recovery mode?
Carlos Perdomo - Réponse
I bought a Asgard (seems operates from HongKong) 2TB NVME PCIe M.2 SSD that I installed into mackbook pro 15in mid 2015 with sintech adapter for conversion to MacBook AHCI controller. The disk utility does not show this SSD. Later I installed in same way another Sabrent SSD 2TB it worked fine.
What might have gone wrong in the fist SSD. Could that SSD itself faulty or incompatible? any fixes available?
GBish - Réponse
Hi there
I recently replaced the HDD in my iMac 2019, 27” Retina 5K with a OWC 1TB SSD which I formatted before installation. After installing the SSD drive my iMac won’t boot up. I’ve tried everything but to no avail. When I turn the power button on nothing happens unless I continuously hold it and then only the fan comes on. Do you have any ideas what could be the problem?
Joseph
JOSEPH BROWN - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 157
7 derniers jours : 989
30 derniers jours : 3,269
Total : 13,399
