Aller au contenu principal
How to String a Tennis Racket
Ce dont vous avez besoin
  1. How to String a Tennis Racket, Cut the old strings from the tennis racket: étape 1, image 1 de 2 How to String a Tennis Racket, Cut the old strings from the tennis racket: étape 1, image 2 de 2
    • Cut the old strings from the tennis racket using a pair of utility scissors and remove them.
    • Be careful not to cut yourself with the ends of the strings.
  2. How to String a Tennis Racket, Place the frame into a stringing machine: étape 2, image 1 de 1
    • Place the frame into a stringing machine by screwing in the four main screws and pulling the racket tight.
  3. How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: étape 3, image 1 de 3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: étape 3, image 2 de 3 How to String a Tennis Racket, Insert the main vertical string into the head of the racquet: étape 3, image 3 de 3
    • Insert the main vertical string into the head of the racket, and thread it down to the neck of the racket and back to the head.
    • Pull and tighten the first main string into a tension rod.
    • The strings should always go under the racquet.
  4. How to String a Tennis Racket, Secure and tighten the end of the string: étape 4, image 1 de 2 How to String a Tennis Racket, Secure and tighten the end of the string: étape 4, image 2 de 2
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the horizontal position.
    • Fix the second string utilizing the second clamp and release the first string.
    • Continue threading the main strings and clamping the strings until all holes have been strung.
    • The stringing pattern: Insert and tighten the string, secure the next string with the clamp, and release the previous string.
  5. How to String a Tennis Racket, Knot the main string: étape 5, image 1 de 2 How to String a Tennis Racket, Knot the main string: étape 5, image 2 de 2
    • Knot the main string after you have secured all the main strings.
    • Release the tension rod and cut off the remaining string.
  6. How to String a Tennis Racket, Horizontal cross strings: étape 6, image 1 de 1
    • Insert the horizontal cross strings from the left to the right and back to the left.
    • Secure and tighten the end of the string by attaching it to the clamp and moving the rod into the vertical position.
    • Continue threading the cross strings and clamping the strings until all holes have been strung by applying the stringing pattern.
    • Weave the cross strings by going over and under repeatedly through the main strings.
  7. How to String a Tennis Racket, Knot all the cross strings: étape 7, image 1 de 1
    • Knot all of the cross strings after you have secured them.
Tzu-Wei
Membre depuis le 09/19/20
153 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G28, Melo-Thaiss Fall 2020 Membre de l'équipe York University, Team S2-G28, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S2G28
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 30
Total : 5,172
