Introduction
This guide is meant to be used for people who have a pair of pants in their possession that are too big for them and would like to size them down in order to wear comfortably. There is the risk of pricking yourself when using a sewing needle for this project, so use caution. Some sewing knowledge is helpful to use with this guide, but it is not necessary.
Ce dont vous avez besoin
Measure how much of the pants to take in by pinching the back of the pants until it's no longer loose in size.
Similar to the previous step, take the needle and following the marked line insert the needle from the outside and poke the needle back out from the inside slightly below the previous stitch.
Repeat this process, going down the white line you marked, leaving the spaces in between each line of thread to be about half of an inch.
Now your pants should fit your size! To undo this process, use a seam ripper to take out the thread.
