Introduction
Active End: The end of the tie that will be used to tie the knot. This can be either the wide end or narrow end of the tie depending on the tie knot.
Shirt Collar: A band of material around the neck of a shirt that can either be folded or unfolded.
Neck Loop: The loop of the tie that goes around the collar.
Keeper Loop: A piece of fabric that is sewn onto the underside of the wide end of the tie that can be used to keep the narrow end of the tie hidden.
Prince Albert: A larger knot than the four-in-hand, this knot is also meant to have a slender, tighter look.
Ce dont vous avez besoin
Take the active end and cross it over the narrow end, so that it points to the left.
Tighten the knot by pulling down on the active end and up on the knot, adjusting for size and evenness.
Congratulations! You've successfully tied the Prince Albert knot!
2 autres ont terminé cette réparation.
