Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model
Ce dont vous avez besoin
    1. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 1, image 1 de 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 1, image 2 de 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model, How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 1, image 3 de 3
      • Unlock the brake barrel adjusters fasteners with a flathead screwdriver in the clockwise direction.
      • Loosening the fasteners will help to loosen the barrel in Step 2.
      Demander à FixBot
      Ajouter un commentaire
    2. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 2, image 1 de 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 2, image 2 de 3 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 2, image 3 de 3
      • Twist in the clockwise direction to tighten the barrel adjusters.
      Demander à FixBot
    3. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 3, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 3, image 2 de 2
      • While squeezing the bike brake check the distance between the brake handle and the bike handle using a measuring device.
      • It should be about an inch if properly tightened.
      • The second image has a loose brake. The distance is less than an inch, where it should be more than an inch (reference step 8 for the right distance). This indicates that the brake is still loose.
      Demander à FixBot
    4. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 4, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 4, image 2 de 2
      • Prepare for the next few steps by loosening the bike brake barrel adjuster if it is fully tightened by turning it clockwise a few times.
      • Start by squeezing the brake arms together as much as possible.
      Demander à FixBot
    5. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 5, image 1 de 1
      • While maintaining the position of the brake arms from Step 4, loosen the bolt that secures the cable clamp using a 5mm Allen Wrench and turn it counter clockwise.
      • Loosen the bolt until the cable can be adjusted easily by hand.
      Demander à FixBot
    6. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 6, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 6, image 2 de 2
      • While keeping the bike brake arms in the same position as described in Step 5, pull the brake cable to adjust the distance between the brake pads and the wheel.
      • Stop pulling when the brake pads are one or two millimeters away from the wheel.
      Demander à FixBot
    7. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 7, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 7, image 2 de 2
      • With the brake arms still squeezed together, use the 5 mm Allen wrench to tighten the cable clamp by turning the wrench in a clockwise direction.
      Demander à FixBot
    8. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 8, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 8, image 2 de 2
      • Tighten the brake barrel adjusters again (as seen in step 2). Do this until the brake handle reaches 25.4 mm from the handle when squeezing.
      • When tightening the brakes, ensure that the brake pads never touch the side of the wheel. If this occurs, then the brake cable was pulled too tight in Step 6 and needs to be loosened.
      Demander à FixBot
    9. How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 9, image 1 de 2 How to Tighten Tektro V-brakes on the Biria: Citibike 700C ST 8-Speed Model: étape 9, image 2 de 2
      • Finally, use the flathead screwdriver to lock the barrel adjuster fastener. Use the screwdriver to twist the fastener in a counterclockwise direction until it is tight.
      Demander à FixBot
Emily Arana
Membre depuis le 04/19/23
169 Réputation
1 tutoriel rédigé
Équipe
UCD-MORRIS-S23S1G1 Membre de l'équipe UCD-MORRIS-S23S1G1
Community
3 membres
10 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 67
Total : 706
