Aller au contenu principal
How to Tighten the Nishiki Aero II Chain
  1. How to Tighten the Nishiki Aero II Chain, How to Tighten the Nishiki Aero II Chain: étape 1, image 1 de 1
    • Shift the rear derailleur into its outermost gear, and the front derailleur into its outer gear.
  2. How to Tighten the Nishiki Aero II Chain: étape 2, image 1 de 3 How to Tighten the Nishiki Aero II Chain: étape 2, image 2 de 3 How to Tighten the Nishiki Aero II Chain: étape 2, image 3 de 3
    • Open the quick-release lever on the rear axle.
    • Quick-release levers are designed to allow you to remove a wheel by hand, with no tools.
    • Continue to loosen the axle by hand until you can freely move the axle in its notch in the rear fork.
  3. How to Tighten the Nishiki Aero II Chain: étape 3, image 1 de 1
    • Move the axle farther back along the notch in the fork so that the chain is taught between the cogs.
    • You might want to ask a friend to help you keep everything steady.
    • Be careful when choosing the new position for the axle; make sure that the wheel will be aligned with the frame.
  4. How to Tighten the Nishiki Aero II Chain: étape 4, image 1 de 1
    • Now that the axle is placed correctly, re-tighten the axle and re-apply the quick-release as shown in Step 1.
Tobias Elder
Membre depuis le 04/25/13
113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 21-53, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 20
Total : 1,380
