Aller au contenu principal
How to True a wheel
Ce dont vous avez besoin
  1. How to True a wheel, How to True a wheel: étape 1, image 1 de 2 How to True a wheel, How to True a wheel: étape 1, image 2 de 2
    • Fit the wheel into the wheel truing stand.
    • The wheel should be snug and securely fixed to the stand.
    • Make sure hub does not have play in it since this will impede your ability to true the wheel.
  2. How to True a wheel: étape 2, image 1 de 2 How to True a wheel: étape 2, image 2 de 2
    • Slowly rotate the wheel.
    • Slowly tighten the calipers until they touch at some point on only one side of the rim.
  3. How to True a wheel: étape 3, image 1 de 2 How to True a wheel: étape 3, image 2 de 2
    • Select the a spoke wrench that fits the spokes on your wheel.
    • Loosen the spokes that attach to the same side of the wheel as the caliper contact point. At the same time, tighten the spokes that attach to the opposite side of the wheel as the caliper contact point. To start, try a half turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until when tightening the calipers, they touch both sides of the rim evenly at every point on the rim.
The wheel should spin without wobbling from side to side or wavering up and down.
aaron thielk
Membre depuis le 10/10/10
1 882 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 5-13, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 membres
17 tutoriels rédigés
2 commentaires
This is a great instruction manual. I especially appreciated the pictures. For those of us who have never fixed a bike, I would not know what a caliper was without the picture.
Thanks!
edwardslaura234 - Réponse
If you don't want to spend money on wheel callipers. Use clothes hanger and tape to the break as a guide.
deankjm - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 7,323
