Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Tune a Deflated Front Suspension on a Mountain Bike
Ce dont vous avez besoin
  1. How to Tune a Deflated Front Suspension on a Mountain Bike, How to Tune a Deflated Front Suspension on a Mountain Bike: étape 1, image 1 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike, How to Tune a Deflated Front Suspension on a Mountain Bike: étape 1, image 2 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike, How to Tune a Deflated Front Suspension on a Mountain Bike: étape 1, image 3 de 3
    • Inspect the front fork for any visible damage, such as scratches on the stanchions or oil leakage around the seals.
    • It may be helpful to flip the bike upside down to get a clear view of the fork.
    • Ensure the compression is set to "On".
    • This is typically done by rotating the compression knob on the fork away from the lock symbol.
  2. How to Tune a Deflated Front Suspension on a Mountain Bike: étape 2, image 1 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 2, image 2 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 2, image 3 de 3
    • Wet a microfiber cloth with a spray bottle and wipe down the stanchions. Making sure to remove any dirt or grime buildup.
    • Clean fork stanchions prevent seal wear and maintain smooth movement.
    • Avoid using high-pressure water near any seals to prevent dirt from being shoved inside.
  3. How to Tune a Deflated Front Suspension on a Mountain Bike: étape 3, image 1 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 3, image 2 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 3, image 3 de 3
    • Remove the cap of the air inflate valve.
    • Attach the shock pump to the air inlet valve by twisting clockwise.
    • Ensure the pump is securely tightened to the valve before moving on.
  4. How to Tune a Deflated Front Suspension on a Mountain Bike: étape 4, image 1 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 4, image 2 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 4, image 3 de 3
    • Use the pump to add air to the fork to set sag.
    • Sag is the amount a bike's suspension compresses when you sit on the bike. Typically, starting with 100 psi is a good starting point for most riders.
    • If a rubber O-ring is not present on the stanchions, carefully attach a zip tie around one of the fork's stanchions. This will be used to measure sag.
    • Sit on the bicycle with your entire weight. Get off, and check the zip tie. Adjust the air pressure until you reach your target sag (20-30% of the fork’s total travel).
    • Unscrew the shock pump each time you set sag.
  5. How to Tune a Deflated Front Suspension on a Mountain Bike: étape 5, image 1 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 5, image 2 de 3 How to Tune a Deflated Front Suspension on a Mountain Bike: étape 5, image 3 de 3
    • Adjust the rebound with the rebound adjustment knob. Turn it to adjust the rebound speed to your preference.
    • Rockshox has a handy graphic displaying a turtle and a hair for slow and fast rebound.
    • Turn it to the slow position for rough trails or the fast position for smoother paths.
    • A good rule of thumb is that the fork should return to its original position without bouncing.
    • Once done, test-ride the new suspension and adjust if needed.
Ligne d'arrivée
Cooper Van Doren
Membre depuis le 10/17/24
121 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 29-11, Watkins Fall 2024 Membre de l'équipe Austin Community College, Team 29-11, Watkins Fall 2024
AUSTINCC-WATKINS-F24S29G11
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 48
Total : 478
