Aller au contenu principal
How to Unclog a Keurig BVMC-KG5
Ce dont vous avez besoin
  1. How to Unclog a Keurig BVMC-KG5, How to Unclog a Keurig BVMC-KG5: étape 1, image 1 de 1
    • Unplug your Keurig.
  2. How to Unclog a Keurig BVMC-KG5: étape 2, image 1 de 1
    • Disassemble all of the parts. This includes: water tank, lid, K-cup holder, and both pieces of the tray where the coffee cup sits.
    • You should not need a screwdriver for this. All of the parts you are disassembling are easily removable by hand.
    • Wash all of the parts in warm, soapy water. Dry well.
  3. How to Unclog a Keurig BVMC-KG5: étape 3, image 1 de 3 How to Unclog a Keurig BVMC-KG5: étape 3, image 2 de 3 How to Unclog a Keurig BVMC-KG5: étape 3, image 3 de 3
    • Unclog the needles using a slightly bent paperclip.
    • With the top of the Keuring open, insert the free end of the paperclip into the three small holes surrounding the needle that pierces the K-Cup.
    • Jiggle the paperclip to loosen any debris.
  4. How to Unclog a Keurig BVMC-KG5: étape 4, image 1 de 1
    • Wipe the whole machine down and reassemble all of the previously removed parts.
  5. How to Unclog a Keurig BVMC-KG5: étape 5, image 1 de 1
    • Fill the water tank with a half water-half vinegar solution.
    • Do not use straight vinegar. It can damage the machine's parts due to the acidity.
    • Run the water-vinegar solution through the machine until you have emptied the tank.
    • Run clean water through the machine. You may have to repeat this step several times to get all of the water-vinegar solution out of the pipes.
Repeat this process every 2-3 months for optimal use of your Keurig, and to increase the lifespan of your coffee brewer.
2 autres ont terminé cette réparation.
Hunter Ashbrook
Membre depuis le 03/21/16
155 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team 1-1, Lauer Spring 2016 Membre de l'équipe Michigan Tech, Team 1-1, Lauer Spring 2016
MTU-LAUER-S16S1G1
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 21
Total : 5,662
