Aller au contenu principal
How to Unclog a Shark Rocket Deluxe Pro Vacuum
Ce dont vous avez besoin
  1. How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 1, image 1 de 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum, How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 1, image 2 de 2
    • Press the wand release button to remove the vacuum body from the roller brush and wand.
  2. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 2, image 1 de 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 2, image 2 de 2
    • Press the button at the bottom of the power cord on the dust bin.
    • Pull off the attached piece.
    • Remove the small filter from the piece.
  3. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 3, image 1 de 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 3, image 2 de 2
    • Pull the lever on top of the dust bin to expose the main filters.
  4. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 4, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 4, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 4, image 3 de 3
    • Carefully squeeze and remove the top filter.
    • Underneath that filter is a second filter. Pull the tab to remove it.
  5. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 5, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 5, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 5, image 3 de 3
    • Squeeze the release on the bottom of the dustbin.
    • Remove the dust bin from the base.
    • Pop the lid open using the slider.
    • Empty the dust bin into the trash.
  6. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 6, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 6, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 6, image 3 de 3
    • Rinse and wipe the plastic pieces removed earlier.
    • Do not use soap.
    • Set the pieces aside to air-dry.
  7. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 7, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 7, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 7, image 3 de 3
    • Place the filters in your sink and rinse out the dirt.
    • Squeeze out any excess water and allow them to air-dry overnight before reinstalling.
    • DO NOT USE SOAP.
  8. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 8, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 8, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 8, image 3 de 3
    • With a wet rag wipe out any dirt buildup on the vacuum casing.
  9. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 9, image 1 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 9, image 2 de 3 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 9, image 3 de 3
    • Turn the base of the vacuum on its side.
    • With your scissors, cut any wrapped hairs or strings that may be stuck on the rollers.
  10. How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 10, image 1 de 2 How to Unclog a Shark Rocket Deluxe Pro Vacuum: étape 10, image 2 de 2
    • Lastly, insert your drain snake into the tube of the vacuum to dislodge any large stuck items.
Savannah Webb
Membre depuis le 06/13/21
181 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 71
Total : 2,055
