Introduction
It’s your worst nightmare. You go to relieve yourself and attempt to get rid of the evidence, only to realize the toilet isn’t cooperating. This happens to the best of us, so you’re not alone. Luckily, this common problem comes with an easy fix using a basic, affordable tool: the mighty toilet plunger.
Ce dont vous avez besoin
A proper toilet plunger has a funnel-shaped flange extending from the bottom of the rubber cup.
A sink plunger just uses a rubber cup, which doesn't form a tight seal inside the toilet bowl.
Insert the toilet plunger into the toilet bowl, making sure that the narrow bell-shaped flange at the end of the plunger is inserted into the drain at the bottom of the toilet bowl.
Once inserted, twist the plunger back and forth a couple of times to make sure it's firmly seated at the bottom of the toilet bowl.
3 autres ont terminé cette réparation.
