Introduction
The Nintendo Game Boy Advance SP is renowned for its compact clamshell design and built-in rechargeable battery, yet its legacy charging jack is increasingly cumbersome in today’s era of universal USB-C. This guide provides a comprehensive, step-by-step procedure for replacing the factory port with a modern USB-C connector. You will learn how to:
- Disassemble the SP’s rear housing without damaging plastic clips or ribbon cables
- De-solder and remove the original proprietary charging jack
- Prepare and align a USB-C breakout module for seamless integration
- Perform precise soldering to ensure a reliable electrical and mechanical connection
- Reassemble the unit and carry out final functional and safety tests
Upgrading your Game Boy Advance SP requires advanced handling of small electronics and hot-work techniques. Observe the following safety measures at all times:
- Soldering Risks
– Molten solder and a hot iron tip can cause severe burns. Always work on a heat-resistant mat, and handle soldering tools by their insulated grips.
– Fumes from solder and flux may be harmful if inhaled—work in a well-ventilated area or use local exhaust. - Electrostatic Discharge (ESD)
– Static electricity can irreversibly damage circuit boards and components. Wear an ESD wrist strap or ground yourself frequently by touching a known earth-grounded object. - Component Damage
– Excessive force when prying or desoldering can crack PCB traces or dislodge nearby parts. Use the proper size of spudgers and solder wick, and apply heat sparingly. - Electrical Safety
– Never attempt repairs on a device that is connected to a power source. Ensure your SP’s battery is removed or fully discharged before beginning. - Small Parts & Debris
– Keep track of all screws, springs, and shims—losing even a single tiny component can compromise your reassembly. Work over a parts tray or magnetic mat.
Note: For any troubleshooting, please refer to the video below.
Ce dont vous avez besoin
Vidéo d'introduction
Turn off the Game Boy Advance SP completely. Then start cleaning the ports located on the back side of the case.
Use a cotton swab dipped in alcohol to gently scrub the inside of the port.
2 autres ont terminé cette réparation.
