Aller au contenu principal
How to Use a 3D printer
  1. How to Use a 3D printer, Before You Turn on the  MarkerBot Replicator: étape 1, image 1 de 1
    • Make sure the filament is full
    • Pick the side you want to extrude from (You will need to input this information when you prepare your file)
    • It doesn't matter which side you pick to extrude from.
    • Use the spray cleaner and paper towels to clean any leftover oil from the platform (Oil buildup may cause the plastic to stick)
  2. How to Use a 3D printer, Control Panel: étape 2, image 1 de 1
    • Press the menu button and scroll through the options
    • Click the Utilities option under the option box
    • Select Level Build Plate option
  3. How to Use a 3D printer, Level The Plate: étape 3, image 1 de 1
    • The plate on the maker bot must be made perfectly level
    • Turn the front leveling knob to change the angle from front to back
    • Turn the right knob to change the angle from left to right
  4. How to Use a 3D printer, After You Level the Plate: étape 4, image 1 de 2 How to Use a 3D printer, After You Level the Plate: étape 4, image 2 de 2
    • Press the "Begin Set-up" button on the control panel to start the process of making sure the plate is level
    • Slip a business card between the extruder and the plate, as extruder pauses at the four waypoints on the plate
    • Make sure there is just enough space between the extruder and the plate to slip in a business card
  5. How to Use a 3D printer, Smart Extruder: this is where the filament goes: étape 5, image 1 de 1
    • Stop! If the filament does not look like the picture on the left, go to the help desk and an ECPL librarian will assist you with loading the Smart Extruder
    • On the control panel select Start Extrusion
    • Once you see filament start to come out of the tip, select Stop Extrusion on the control panel
    • The plastic will be hot so wait 20 sec, then remove it from the build plate
  6. How to Use a 3D printer, Making a Test Object: étape 6, image 1 de 1
    • Before you make your object, you should run a test object to make sure the 3D printer is set up correctly
    • Use the dial and select Test File 1 for a dragon and Test File 2 for a street cone
    • Push the dial and you will be taken to a file info page
    • Select Print
    • When the print is done, you should have a 1/2" plastic dragon or pyramid
    • Let the object cool before removing it
  7. How to Use a 3D printer, Check the Test Object: étape 7, image 1 de 1
    • Your test object should look like one of the two items on the left
    • Notice the details of the object, if something does not look right, you should repeat the setup before you print off your design
    • If the test object looks perfect then it is time to print off your design
  8. How to Use a 3D printer, Insert Your File: étape 8, image 1 de 1
    • If the test objects are perfect, then you can upload your file with your object into the machine
    • Insert a thumb drive that has the .makerbot file you want printed into the USB port on the right of the Control Panel
    • Select Upload File on the LCD Panel
    • The LCD panel will display all compatible files on the thumb drive
    • Select the file that you want to upload to the MakerBot
    • Repeat step 6 selecting the .makerbot file you want to print
  9. How to Use a 3D printer, When Your Object Is Complete: étape 9, image 1 de 1
    • Wait until the object has cooled before you remove it from the plate (1-2 minutes is usually enough time)
    • When the object has cooled remove it from the 3D printer and admire it deeply
3 autres ont terminé cette réparation.
Jason Swearingen
Membre depuis le 11/12/15
281 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 27
Total : 1,035
