Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to Use a MarkerBot Replicator 3D printer
    1. How to Use a MarkerBot Replicator 3D printer, Before You Turn on the  MarkerBot Replicator: étape 1, image 1 de 1
      • Make sure the filament is full
      • Pick the side you want to extrude from (You will need to input this information when you prepare your file)
      • It doesn't matter which side you pick to extrude from.
      • Use the spray cleaner and paper towels to clean any leftover oil from the platform (Oil buildup may cause the plastic to stick)
      Demander à FixBot
      Ajouter un commentaire
    2. How to Use a MarkerBot Replicator 3D printer, Control Panel: étape 2, image 1 de 1
      • Press the menu button and scroll through the options
      • Click the Utilities option under the option box
      • Select Level Build Plate option
      Demander à FixBot
    3. How to Use a MarkerBot Replicator 3D printer, Level The Plate: étape 3, image 1 de 1
      • The plate on the maker bot must be made perfectly level
      • Turn the front leveling knob to change the angle from front to back
      • Turn the right knob to change the angle from left to right
      Demander à FixBot
    4. How to Use a MarkerBot Replicator 3D printer, After You Level the Plate: étape 4, image 1 de 2 How to Use a MarkerBot Replicator 3D printer, After You Level the Plate: étape 4, image 2 de 2
      • Press the "Begin Set-up" button on the control panel to start the process of making sure the plate is level
      • Slip a business card between the extruder and the plate, as extruder pauses at the four waypoints on the plate
      • Make sure there is just enough space between the extruder and the plate to slip in a business card
      Demander à FixBot
    5. How to Use a MarkerBot Replicator 3D printer, Smart Extruder: this is where the filament goes: étape 5, image 1 de 1
      • Stop! If the filament does not look like the picture on the left, go to the help desk and an ECPL librarian will assist you with loading the Smart Extruder
      • On the control panel select Start Extrusion
      • Once you see filament start to come out of the tip, select Stop Extrusion on the control panel
      • The plastic will be hot so wait 20 sec, then remove it from the build plate
      Demander à FixBot
    6. How to Use a MarkerBot Replicator 3D printer, Making a Test Object: étape 6, image 1 de 1
      • Before you make your object, you should run a test object to make sure the 3D printer is set up correctly
      • Use the dial and select Test File 1 for a dragon and Test File 2 for a street cone
      • Push the dial and you will be taken to a file info page
      • Select Print
      • When the print is done, you should have a 1/2" plastic dragon or pyramid
      • Let the object cool before removing it
      Demander à FixBot
    7. How to Use a MarkerBot Replicator 3D printer, Check the Test Object: étape 7, image 1 de 1
      • Your test object should look like one of the two items on the left
      • Notice the details of the object, if something does not look right, you should repeat the setup before you print off your design
      • If the test object looks perfect then it is time to print off your design
      Demander à FixBot
    8. How to Use a MarkerBot Replicator 3D printer, Insert Your File: étape 8, image 1 de 1
      • If the test objects are perfect, then you can upload your file with your object into the machine
      • Insert a thumb drive that has the .makerbot file you want printed into the USB port on the right of the Control Panel
      • Select Upload File on the LCD Panel
      • The LCD panel will display all compatible files on the thumb drive
      • Select the file that you want to upload to the MakerBot
      • Repeat step 6 selecting the .makerbot file you want to print
      Demander à FixBot
    9. How to Use a MarkerBot Replicator 3D printer, When Your Object Is Complete: étape 9, image 1 de 1
      • Wait until the object has cooled before you remove it from the plate (1-2 minutes is usually enough time)
      • When the object has cooled remove it from the 3D printer and admire it deeply
      Demander à FixBot
3 autres ont terminé cette réparation.
Jason Swearingen
Membre depuis le 11/12/15
281 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 54
Total : 1,376
