Aller au contenu principal
How to Winterize Sprinkler System
  1. How to Winterize Sprinkler System, How to Winterize Sprinkler System: étape 1, image 1 de 2 How to Winterize Sprinkler System, How to Winterize Sprinkler System: étape 1, image 2 de 2
    • Shut the water supply off to the irrigation system. (usually found in the utility room or basement)
  2. How to Winterize Sprinkler System: étape 2, image 1 de 1
    • Obtain an air compressor. (you can rent one from the local Home Depot)
  3. How to Winterize Sprinkler System: étape 3, image 1 de 3 How to Winterize Sprinkler System: étape 3, image 2 de 3 How to Winterize Sprinkler System: étape 3, image 3 de 3
    • Connect a hose to the compressor, and one to the water line (in basement).
  4. How to Winterize Sprinkler System: étape 4, image 1 de 1
    • Turn the compressor on.
  5. How to Winterize Sprinkler System: étape 5, image 1 de 1
    • Start manually turning on each station of the system one by one.
  6. How to Winterize Sprinkler System: étape 6, image 1 de 1
    • Let the air blow the water out for about 2 minutes per station.
  7. How to Winterize Sprinkler System: étape 7, image 1 de 3 How to Winterize Sprinkler System: étape 7, image 2 de 3 How to Winterize Sprinkler System: étape 7, image 3 de 3
    • Unplug the hose from the compressor and the water line.
  8. How to Winterize Sprinkler System: étape 8, image 1 de 2 How to Winterize Sprinkler System: étape 8, image 2 de 2
    • Turn the air compressor off and then turn the sprinkler system off from the control panel outside.
Corneliu Fabian
Membre depuis le 10/07/19
157 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 640
