Aller au contenu principal
Pour réparer ensemble - Je crée un compte
How to add wireless charging to Samsung Galaxy S4 mini
Ce dont vous avez besoin
  1. How to add wireless charging to Samsung Galaxy S4 mini, Preparing the wireless charging pad, in order to fit inside the back cover: étape 1, image 1 de 2 How to add wireless charging to Samsung Galaxy S4 mini, Preparing the wireless charging pad, in order to fit inside the back cover: étape 1, image 2 de 2
    • Disassembling the wireless charging pad, to make it as thin as possible.
    • Inside there is a rubber pad, in order to prevent excessive heat disipating through the back of the charging pad, remove this.
    Demander à FixBot
    Ajouter un commentaire
  2. How to add wireless charging to Samsung Galaxy S4 mini, Adding connecting wires to the wireless charging pad: étape 2, image 1 de 1
    • Soldering on thin flexible wires to the + and - on the wireless charging pad
    Demander à FixBot
  3. How to add wireless charging to Samsung Galaxy S4 mini, Gaining access to the internal USB board: étape 3, image 1 de 1
    Demander à FixBot
  4. How to add wireless charging to Samsung Galaxy S4 mini, Soldering wireless charging pad onto the USB port: étape 4, image 1 de 2 How to add wireless charging to Samsung Galaxy S4 mini, Soldering wireless charging pad onto the USB port: étape 4, image 2 de 2
    • Soldering the wireless charging pad connection + to CN2 on the USB port and - to the ground on the USB port, any part of the external metal surface should work.
    Demander à FixBot
  5. How to add wireless charging to Samsung Galaxy S4 mini, Altering back cover to fit the wires inside the phone: étape 5, image 1 de 1
    • Use a small file to make room for the wires on the back frame just below where the battery sits.
    Demander à FixBot
  6. How to add wireless charging to Samsung Galaxy S4 mini, Placing the back cover once more: étape 6, image 1 de 1
    • Using the USB board replacement guide, step 3 - 8 in reverse order to place the back cover, making sure the wires to the charging pad fits through the ready made holes.
    Demander à FixBot
  7. How to add wireless charging to Samsung Galaxy S4 mini, Placing wireless charging pad to keep NFC functioning: étape 7, image 1 de 1
    • Placing the wireless charging pad, slightly off center to keep NFC, which is implemented in the battery, working.
    Demander à FixBot
  8. How to add wireless charging to Samsung Galaxy S4 mini, Booting the phone to check everything is working: étape 8, image 1 de 1
    • Samsung Galaxy S4 mini booting after fitting wireless charging pad.
    Demander à FixBot
While one would think, soldering a charging coil onto the charging connections would yield in a shortening of the normal connections to the battery, how ever it turns out the combination is very robust.
The phone will charge without issues on a cable connection, aswell as on the wireless charging pad, and data connection via cable remains intact.
By using the charging pad, the coil do get a bit warm, the insulation material removed in step 1, to make it as thin as possible can have an effect on the heat dissepating to the battery from the coil.
Over my usage of this setup I have not yet come across any miss behaviour of the phone due to the charging over wireless or any other issues arisen from this configuration.
11 autres ont terminé cette réparation.
Kenneth H. Nielsen
Membre depuis le 08/04/11
449 Réputation
1 tutoriel rédigé
2 commentaires de tutoriel
I tryed to copy your guide and soldered everything in place (5V to this usb pin & Ground to the usb-port), messed up the charging coil a bit by ripping off the whole connector (I now have only 2 pads left for soldering to) and if i place it on the dock, the flashy lights on the dock will turn on, but the phone will not charge.
As you said normal charging by usb works fine, but i cant figure out my problem.
Jann Bern - Réponse Partager
Hi Jann
I have used this approach on three different phones, you need to make sure the + connection on the charging pad is soldered onto the connection on the USB port that is marked by the CN2 arrow on the main board.
I had one that showed the same issues you are describing here, taking the phone apart and resoldering the + connection solved that issue.
Best regards
Kenneth H. Nielsen - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 52
Total : 19,083
