Aller au contenu principal
How to adjust Razor A steering column
  1. How to adjust Razor A steering column, How to adjust Razor A steering column: étape 1, image 1 de 2 How to adjust Razor A steering column, How to adjust Razor A steering column: étape 1, image 2 de 2
    • Locate the tightening assembly. The tightening assembly consists of:
    • An upper nut
    • A lower nut
  2. How to adjust Razor A steering column: étape 2, image 1 de 1
    • This step refers to clockwise and counterclockwise rotation. This is as viewed from the top.
    • If loosening the steering column, follow these steps:
    • Turn the upper nut counterclockwise.
    • Turn the lower nut counterclockwise until it is tight against the upper nut.
    • If the steering column is still too tight, repeat the above two steps until reaching the desired steering column looseness.
    • If tightening the steering column, follow these steps:
    • Turn the lower nut clockwise until reaching the desired steering column tightness.
    • Turn the upper nut clockwise until it is tight against the lower nut.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Jordyn
Membre depuis le 10/09/12
544 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-13, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 membres
10 tutoriels rédigés
8 commentaires
what move it with your hands? - didn't help
Heather McCasland - Réponse
I couldn't turn this by hand. not sure who writes this advice. trying a pipe wrench.
jmackenzie1234 -
Thanks you! Why doesn't the owners manual have this?
Jessica - Réponse
Thanks for the instructions. They helped me fix my son’s scooter.
That Dude - Réponse
Thank you for showing the way how to adjust Razor scooter. This instruction help me to adjust my scooter.
Jessie Allen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 55
30 derniers jours : 185
Total : 40,874
