Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Sometimes a scooter will move in a different direction than the user directs it. This guide will demonstrate how to align the steering column with the front wheel, and so that the scooter moves properly in the right direction.
Pièces
Aucune pièce spécifiée.
  1. Locate the collar clamp near the base of the steering column. Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it. The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
    • Locate the collar clamp near the base of the steering column.
    • Insert a 3/16" Allen wrench into the screw in the collar clamp and loosen it.
    • The collar clamp will be free to move and may slide around the steering column. When reassembling, return it to its original position.
  2. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  3. Firmly grasp the steering column and turn the wheel by hand. View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • Firmly grasp the steering column and turn the wheel by hand.
    • View the scooter along the steering column. Be sure the wheel is perpendicular to the handlebars.
    • The second picture above shows a correct alignment of the steering column from this view.
Ligne d'arrivée
15 autre(s) ont terminé cette réparation.
Jordyn
Membre depuis le 09/10/2012
502 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 9-13, Amido Fall 2012 Membre de l'équipe Cal Poly, Team 9-13, Amido Fall 2012
CPSU-AMIDO-F12S9G13
4 membres
5 tutoriels rédigés
This is so unhelpful.
Linh Tran - Réponse
Great guide! Thanks so much helped me to fix my old scooter and save approx. $50
Max Kittens - Réponse
Wow, fixed all the kids scooters on the block….THANK YOU!!!!!
Kathy Earhart - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 13
7 derniers jours : 103
30 derniers jours : 391
Total : 21,668
