Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to apply new adhesive on the Apple Watch Series 1 after opening it up or having the Force Touch Sensor replaced.
  1. Use a plastic opening tool to scrape adhesive off the back of the screen. Use a plastic opening tool to scrape adhesive off the back of the screen.
    • Use a plastic opening tool to scrape adhesive off the back of the screen.
  2. You may be able to peel up the adhesive with tweezers. Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
    • You may be able to peel up the adhesive with tweezers.
    • Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
  3. Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Be sure to get both the double-sided adhesive and the brown backing paper.
    • Be very careful not to fold, bend, or stretch the adhesive tape, as this will make it too thick to seal the screen without a ridge between the screen and the case.
  4. Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests. Start in a corner with the tape as close to the corner wall as possible. Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
    • Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests.
    • Start in a corner with the tape as close to the corner wall as possible.
    • Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
  5. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Use a plastic opening tool to reconnect the display data and digitizer cable connectors. Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
    • Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
    • Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
  7. To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down. Snap the upper bracket in place. Snap the upper bracket in place.
    • To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down.
    • Snap the upper bracket in place.
  8. Line the battery connector up with its mate on the cable inside the watch body. Use tweezers to press the two connectors together. Use tweezers to press the two connectors together.
    • Line the battery connector up with its mate on the cable inside the watch body.
    • Use tweezers to press the two connectors together.
  9. If your replacement battery came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive. Rotate the battery down into its slot, and press it into position. Press the battery down against the S1 to re-adhere it in place.
    • If your replacement battery came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive.
    • Rotate the battery down into its slot, and press it into position.
    • Press the battery down against the S1 to re-adhere it in place.
    • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
  10. Use tweezers to peel off the adhesive backing strip.
    • Use tweezers to peel off the adhesive backing strip.
    • Peel the backing strip up halfway, then snip it with scissors so you can peel the rest off without it snagging on the display.
  11. Move the screen back to the right, folding the display data and digitizer cables neatly. Center the screen over the case and press it down firmly onto the adhesive. Center the screen over the case and press it down firmly onto the adhesive.
    • Move the screen back to the right, folding the display data and digitizer cables neatly.
    • Center the screen over the case and press it down firmly onto the adhesive.
Ligne d'arrivée
20 autre(s) ont terminé cette réparation.
Tobias Isakeit
Membre depuis le 31/03/2014
61 601 Réputation
131 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
10 268 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 38
30 derniers jours : 135
Total : 5,403
