Aller au contenu principal
How to change Tool for DeepAccess
Ce dont vous avez besoin
  1. How to change Tool for DeepAccess, How to change Tool for DeepAccess: étape 1, image 1 de 1
    • Prepare Tools and replacement parts.
  2. How to change Tool for DeepAccess, Remove wedge from transducer: étape 2, image 1 de 3 How to change Tool for DeepAccess, Remove wedge from transducer: étape 2, image 2 de 3 How to change Tool for DeepAccess, Remove wedge from transducer: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    • Grab wegdge with tweezers
    • Loosen the screw. (while holding the wedge)
    • Get rid of the copper screw. To NOT use it more than once
  3. How to change Tool for DeepAccess, Place the new wedge in the transducer.: étape 3, image 1 de 3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: étape 3, image 2 de 3 How to change Tool for DeepAccess, Place the new wedge in the transducer.: étape 3, image 3 de 3
    • Put the wedge in the tranducer from below.
    • Take care, that the Tool Top is flush with the Transducer surface
    • Correct Placement. Tool is flush with transducer.
    • Incorrect Placement. tool is too high.
  4. How to change Tool for DeepAccess, Fasten the copper screw: étape 4, image 1 de 2 How to change Tool for DeepAccess, Fasten the copper screw: étape 4, image 2 de 2
    • Fasten the screw lightly
    • Tighten the screw just so the wedge does not slip out of the tranducer.
    • in case of appliying too much torque. Use a new screw and get rid of the old one.
  5. How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: étape 5, image 1 de 3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: étape 5, image 2 de 3 How to change Tool for DeepAccess, Adjust wedge heigth with setting gauge: étape 5, image 3 de 3
    • Place gauge below Tool
    • Loosen the screw so the wedge slides onto the gauge Lever.
    • Lift the gauge up until in contact with the transducer horn.
    • Now the Tool-Top should be flush with the Transducer-Horn
    • Tighten the screw with the torque- wrench
    • Use Torque wrench with 18cN limitation
    • Use tweezers to push the wire down the wire hole, until it Ends some cm below the tool wedge.
    • Use scissors to cut the (contaminated) Wire down to a length of about 1cm below wedge end.
  6. How to change Tool for DeepAccess, Thread Wire through Wedge-hole: étape 7, image 1 de 3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: étape 7, image 2 de 3 How to change Tool for DeepAccess, Thread Wire through Wedge-hole: étape 7, image 3 de 3
    • Use tweezers to thread the wire through the hole at the end of the wedge.
    • Afet threading pull the wire some cm through the hole.
Hans Panz
Membre depuis le 03/10/16
289 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 140
