Aller au contenu principal
How to charge Canon PowerShot A4000 IS battery
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. How to charge Canon PowerShot A4000 IS battery, Battery: étape 1, image 1 de 1
    • Using your finger, apply light pressure to the grooves at the top right corner of the camera to slide the door to the battery compartment open.
  2. How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: étape 2, image 1 de 2 How to charge Canon PowerShot A4000 IS battery, Inside The Battery Compartment: étape 2, image 2 de 2
    • Using your finger, press the red switch backwards, away from the lens to release the battery.
    • The battery has an arrow on it pointing in the direction the battery needs to be oriented in the camera.
  3. How to charge Canon PowerShot A4000 IS battery, Charging the Battery: étape 3, image 1 de 3 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: étape 3, image 2 de 3 How to charge Canon PowerShot A4000 IS battery, Charging the Battery: étape 3, image 3 de 3
    • Use the Battery Removal guide to remove your camera battery. Once the battery is removed, insert it into the charger that came with your PowerShot A4000 camera.
    • Maker sure the arrows on the charger and camera match up or the battery will not charge properly.
    • Once the battery is inserted into the charger, it is ready to be plugged into an outlet.
    • A yellow light will come on once the battery begins charging. The light will turn green when the battery is fully charged.
  4. How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: étape 4, image 1 de 2 How to charge Canon PowerShot A4000 IS battery, Reinserting the Battery: étape 4, image 2 de 2
    • Once the battery is fully charged, use the guide on removing your camera battery found here: Battery Removal, in reverse, to reinsert your battery.
    • Make sure to line up the battery with the arrow side facing toward the lens side of the camera. When you press the battery down, the red switch should click back into place automatically, holding the battery in place.
Ansley Gardner
Membre depuis le 10/13/14
761 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 1-3, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 616
