Aller au contenu principal
How to clean Microtek ScanMaker 5900 glass
Ce dont vous avez besoin
  1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: étape 1, image 1 de 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: étape 1, image 2 de 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: étape 1, image 3 de 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: étape 2, image 1 de 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: étape 2, image 2 de 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: étape 2, image 3 de 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: étape 3, image 1 de 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: étape 3, image 2 de 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: étape 3, image 3 de 3
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: étape 4, image 1 de 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: étape 4, image 2 de 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: étape 4, image 3 de 3
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: étape 5, image 1 de 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: étape 5, image 2 de 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: étape 5, image 3 de 3
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  6. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: étape 6, image 1 de 1
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
Steven Shaginyan
Membre depuis le 10/12/11
39 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-9, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 2,556
