Introduction
With these remotes it seems to be a common problem some buttons cease to work after a couple of years. Usually, you just need to open the remote and clean the circuit board.
  1. For later testing: X marks butttons which still work, O marks buttons that don't.
    • For later testing: X marks butttons which still work, O marks buttons that don't.
  2. Open battery housing and remove the batteries Remove the screw located in the center of the battery housing
    • Open battery housing and remove the batteries
    • Remove the screw located in the center of the battery housing
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Top and bottom shell of the remote are held together by 4 latches per side. The most fore and aft ones are located about 1cm from each end
    • Pry them open with a small flat head. If you're carefull that will leave only tiny scratches, but it does take some force
  5. Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote If necessary, at contact spray or alike to the buttom of the rubber buttons
    • Once open, remove the insides and clean them from all the drinks and what not that has been poored over the remote
    • If necessary, at contact spray or alike to the buttom of the rubber buttons
  6. After cleaning and before full re-assembly, you might want to try if things improved.
    • After cleaning and before full re-assembly, you might want to try if things improved.
    • Put the cicruit board back in, add batteries and put the rubber mats onto the circuit board
    • If the repair worked, you should the red top LED flashing
    • Put it all back together again. (Don't forget the screw in the battery housing.)
    • You might need some new batteries as well
14 autre(s) ont terminé cette réparation.
andre
Membre depuis le 12/03/2012
1 121 Réputation
3 tutoriels rédigés
22 commentaires
Having trouble with the latches. Can you explain the technique you used to pry them open?
Thanks!
bob - Réponse
Hi Bob. Force, brute force. Sorry, I don't have a better advice for you. ;-)
andre -
thanks, I fixed mine using your guide.
surfer - Réponse
You are a life saver, just fixed my onkyo RC-737m control with this guide... Broken a plastic clip but can't tell when it's back together. Cheers again! Leon
Leon Parsons - Réponse
Géniaaaaaaaaaaal!
Deux télécommandes dont les boutons du volume ne répondaient plus! Et hop c'est revenu ;-)
Merciiiiiiii
Thierry Paulet - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 57
30 derniers jours : 243
Total : 28,968
