Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Outils
Pièces
Aucune pièce spécifiée.
  1. Turn the calculator over so that the blue Texas Instruments logo is up.
    • Turn the calculator over so that the blue Texas Instruments logo is up.
    • Slide the blue case downward until it is completely removed from the calculator.
  2. Step 2 and 3 to detach the keyboard are optional, but may prevent permanent damage to the calculator.
    • Step 2 and 3 to detach the keyboard are optional, but may prevent permanent damage to the calculator.
    • Turn the calculator over and locate the sliding latch on the back of the calculator.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. At the same time, slide the latch to the right and pull the keypad downward.  This should completely separate the keypad from the calculator. At the same time, slide the latch to the right and pull the keypad downward.  This should completely separate the keypad from the calculator.
    • At the same time, slide the latch to the right and pull the keypad downward. This should completely separate the keypad from the calculator.
  5. Now that you have detached the keypad, gather the cotton swabs and rubbing alcohol.
    • Now that you have detached the keypad, gather the cotton swabs and rubbing alcohol.
    • Dampen a cotton swab by placing 1 to 3 drops of rubbing alcohol on the tip.
    • Be careful not to completely soak the the cotton swab with the rubbing alcohol.
    • DO NOT pour the rubbing alcohol directly onto the keypad. Too much liquid exposure can permanently damage it.
  6. Use the moistened cotton swab and rub it around each button, in crevices, and anywhere on the keypad that may have dirt. Replace the swab as often as desired.
    • Use the moistened cotton swab and rub it around each button, in crevices, and anywhere on the keypad that may have dirt. Replace the swab as often as desired.
    • Keep the rubbing alcohol away from the calculator's visual display. Water exposure to the screen can permanently damage the screen.
Now your buttons should be free of any stickiness.
Mariel Sanchez
Membre depuis le 27/09/2012
22 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-52, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 42
Total : 4,305
