Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Brakes slow your bike down when you pull on the brake lever on the handlebar. The brake calipers are connected to the brake levers by a cable that squeezes the brake-pads that are attached to the brake calipers. When the brake pads contact the rims they slow down the rim of the wheel, slowing down the bike.
Pièces
Aucune pièce spécifiée.
  1. Squeeze the calipers together, and remove the brake cable. Squeeze the calipers together, and remove the brake cable. Squeeze the calipers together, and remove the brake cable.
    • Squeeze the calipers together, and remove the brake cable.
  2. Loosen the break caliper bolt, and remove the brake caliper. Loosen the break caliper bolt, and remove the brake caliper. Loosen the break caliper bolt, and remove the brake caliper.
    • Loosen the break caliper bolt, and remove the brake caliper.
  3. Inspect the brake pad. If the pad has worn down past the “wear line”, then it needs to be replaced. Inspect the brake pad. If the pad has worn down past the “wear line”, then it needs to be replaced.
    • Inspect the brake pad. If the pad has worn down past the “wear line”, then it needs to be replaced.
  4. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  5. Clean and lubricate the parts as necessary before reattaching the caliper arms. Bolt the caliper arms back on while making sure the the pin on the back side of the caliper arm lines back up with the one of the holes in the frame. Each side should be in the same hole. Bolt the caliper arms back on while making sure the the pin on the back side of the caliper arm lines back up with the one of the holes in the frame. Each side should be in the same hole.
    • Clean and lubricate the parts as necessary before reattaching the caliper arms.
    • Bolt the caliper arms back on while making sure the the pin on the back side of the caliper arm lines back up with the one of the holes in the frame. Each side should be in the same hole.
  6. Reattach the brake cable to the calipers. Reattach the brake cable to the calipers.
    • Reattach the brake cable to the calipers.
  7. Loosen the brake pad bolt. Loosen the brake pad bolt.
    • Loosen the brake pad bolt.
  8. Get an ordinary piece of paper, and fold it twice over. Place the sheet of paper between the brake pad and the rim in the position shown.
    • Get an ordinary piece of paper, and fold it twice over.
    • Place the sheet of paper between the brake pad and the rim in the position shown.
  9. Align the brake pad so that it is flush with the rim, with no part touching the rubber of the tire. Have somebody clamp down very tightly on the brakes. Tighten the brake pad bolt in place.
    • Align the brake pad so that it is flush with the rim, with no part touching the rubber of the tire.
    • Have somebody clamp down very tightly on the brakes.
    • Tighten the brake pad bolt in place.
  10. Tighten/loosen the tension adjustment screws on each the caliper arm to adjust the resting distance of each brake pad, so that each pad is equally distant from the rim. Tightening the screw will shift the caliper outward from the bike, loosening it will shift it inward. Tighten/loosen the brake adjuster on the handle bars such that when you clamp down on the brakes, the brake lever stops before hitting the handle bar. This will set the distance between the brake pads and the rim. Tighten the lock nut on the brake adjuster to permanently set its position.
    • Tighten/loosen the tension adjustment screws on each the caliper arm to adjust the resting distance of each brake pad, so that each pad is equally distant from the rim. Tightening the screw will shift the caliper outward from the bike, loosening it will shift it inward.
    • Tighten/loosen the brake adjuster on the handle bars such that when you clamp down on the brakes, the brake lever stops before hitting the handle bar. This will set the distance between the brake pads and the rim.
    • Tighten the lock nut on the brake adjuster to permanently set its position.
Ligne d'arrivée
40 autre(s) ont terminé cette réparation.
Travis Tonder
Membre depuis le 05/10/2010
2 607 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 5-13, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 membres
11 tutoriels rédigés
“what does it mean if the point is red???? “
I believe that is indicating that this step corresponds to an image which highlights a specific step. I saw this two times, in step 4 and step 9. For step 4, it shows the highlight in the second image and for step 9, the highlight is in the first image. It seems that the red bullet point is just to make it easier to map the step to the image.
Hope this helps
Tony - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 95
7 derniers jours : 875
30 derniers jours : 3,333
Total : 82,433
