Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If you have print quality problems, clean the corona wire.
  1. Press the front cover release button.
    • Press the front cover release button.
    • Keep the button pressed and pull the cover toward yourself.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. With the front cover in the downward position, the drum & toner unit will be visible. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer. Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
    • With the front cover in the downward position, the drum & toner unit will be visible.
    • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
  4. Clean the corona wire inside the drum unit by gently sliding the blue tab all the way to left and then back to the far right.  Repeat several times. Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs. Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs.
    • Clean the corona wire inside the drum unit by gently sliding the blue tab all the way to left and then back to the far right. Repeat several times.
    • Make sure the arrow on the tab lines up with the arrow on the drum unit before you place it back into the printer. If the tab is in the wrong place, a vertical line might appear on future print jobs.
2 autre(s) ont terminé cette réparation.
Nathan Ruiz
Membre depuis le 14/01/2010
159 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-14, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 12,083
