Aller au contenu principal
How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers
Ce dont vous avez besoin
  1. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Back Panel: étape 1, image 1 de 1
    • Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
  2. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: étape 2, image 1 de 2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Inner Back Pannel: étape 2, image 2 de 2
    • Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
  3. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: étape 3, image 1 de 2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Remove Upper Portion: étape 3, image 2 de 2
    • Press down on the two plastic hinges to remove the upper portion of printer.
  4. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Unplug Speaker Wire: étape 4, image 1 de 1
    • Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
  5. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: étape 5, image 1 de 2 How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray: étape 5, image 2 de 2
    • Rotate the printer so the paper tray is facing towards you.
    • Gently lift the scanner tray up and away from the printer.
    • Press the gray plastic tabs inward to release the tabs from the printer.
  6. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Removing Scanner Tray - cont.: étape 6, image 1 de 1
    • Returning to the back of the printer, remove the scanner from the back hinges.
    • With pressure applied, the scanner will detach easily.
  7. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: étape 7, image 1 de 1
    • Gently grasp and unplug the two white ribbon cables from the printer body.
    • Be sure to grasp the cable at the connector and not to pull on the wires themselves.
  8. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: étape 8, image 1 de 1
    • Unplug the white plastic multi-wire connector (with orange, black, red, and brown wires) from it's port.
    • Be sure to grasp the white connector and not to pull on the wires themselves.
  9. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Detaching the Scanner Tray: étape 9, image 1 de 1
    • Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
  10. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: étape 10, image 1 de 1
    • Using the T10 Torx Security Bit Screwdriver, remove the four black screws holding the printer carriage cover in place.
  11. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: étape 11, image 1 de 1
    • Depress plastic tabs to release the cover from the sides.
    • There is nothing holding the left side panel in place, so pull it away from the printer body.
  12. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers: étape 12, image 1 de 1
    • Turn the smallest white plastic gear on the left side of the printer to rotate feed rollers.
  13. How to clean the HP PSC 2410 Photosmart All In One Printer Feed Rollers, Clean Rollers: étape 13, image 1 de 1
    • While rotating the feed rollers, clean them with purified or distilled water and a lint-free cloth.
3 autres ont terminé cette réparation.
Cody Long
Membre depuis le 04/12/11
153 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 12-31, Maness Spring 2011 Membre de l'équipe Cal Poly, Team 12-31, Maness Spring 2011
CPSU-MANESS-S11S12G31
5 membres
9 tutoriels rédigés
Un commentaire
Nice instructions, but there's nothing here about the video card readers on the right front. Can't get the right-side panel off. Otherwise, the instructions are well displayed.
Gayle Bryan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 18
Total : 12,030
