Introduction
The feed rollers are 4 individual rubber coated rollers that pull the paper through the printer. To access the rollers, the scanner tray must be removed. Once the feed rollers are exposed, cleaning is simple and requires little time.
Ce dont vous avez besoin
Remove the back panel by inserting your fingers into the indentations next to the tabs. Press the tabs inward towards each other while pulling the back panel toward you.
Using the T10 Torx Security Bit Screwdriver, unscrew the screws on the upper left and right corners of the inner panel to remove the inner back panel.
Press down on the two plastic hinges to remove the upper portion of printer.
Grasp the plastic plug on the end of the speaker wire, then gently pull the plug away from the printer until the wire is removed.
Rotate the printer so the paper tray is facing towards you.
Gently lift the scanner tray up and away from the printer.
Press the gray plastic tabs inward to release the tabs from the printer.
Returning to the back of the printer, remove the scanner from the back hinges.
Detach the scanner tray from the printer by lifting the scanner tray off the printer body.
Using the T10 Torx Security Bit Screwdriver, remove the four black screws holding the printer carriage cover in place.
While rotating the feed rollers, clean them with purified or distilled water and a lint-free cloth.
3 autres ont terminé cette réparation.
Un commentaire
Nice instructions, but there's nothing here about the video card readers on the right front. Can't get the right-side panel off. Otherwise, the instructions are well displayed.
