Introduction
The hollow needle that pierces the top of the K-Cup can get clogged by coffee particles. If you try to flush it by forcing tools or fluid into the needle's exit, you risk damaging the back-flow preventing check valve. This guide shows how to disassemble just enough of the head assembly to clean the top needle from its inlet side.
Ce dont vous avez besoin
Identifying the parts: 1.A is the water reservoir cover. 1.B is the "Head". The needle that punctures the K-Cup is in here.
Lift off the water reservoir cover, revealing 2.A: the overflow spout.
When the top needle is clogged, running the Keurig will make most of the hot water come out the overflow spout, back into the water reservoir, instead of through your coffee. That symptom lets you know you might benefit from following this procedure.
Point the tip of your Philips-head screw driver up and remove the two screws on the underside of the head. (circled). Be careful you don't drop and lose them!
7 autres ont terminé cette réparation.
12 commentaires
I discovered that if you pinprick the lid in the center, where the needle goes, just before placing the cup in the machine, the frequency and severity of plugging is reduced by a factor of 10. Try it and comment back. (Helps to also close the top slowly).
I called Keurig about the clogging problem, and they claimed that manually forcing the cup to be pierced by the bottom needle when placing the cup in the holder will help to reduce clogs, but I am not sure why this is any better than using the handle. I still have problems with clogging, and I have had to use the included Keurig 2.0 Brewer Top Needle Cleaning Maintenance Accessory, but that is only a temporary fix.
Joe Hunt -
There were a couple of items omitted from this post. 1. When you remove the first two screws, the cover is still connected to the lower assembly by two posts that are pressed into the lower part. Holding the cover near the back and wiggling the sides up and down will pull the posts out so you can move it. 2. On my version of the keurig, there is an assembly that holds a one way valve. That was the problem with mine. I removed the assembly, tried to blow through it and couldn't. I pushed on the back of the valve and it came loose. Problem solved. I took a picture of the valve assembly but couldn't figure out how to attach it here. I'll add it elsewhere if I can figure it out.
Hate my Keurig. It's four months old and I've had to use the maintenance cleaning kit so often I've lost count. And it never cleans the coffee out of the needle with 5 up and downs as it states it should. It sually takes me up to 5 attempts which can take a lot of time in the mornings when all you want is a coffee so you can get to work.
J;ai un problème avec ma keurig b77 a coule avec plusieurs jet je ne suis pas capable de prendre le café en cup noir.Je l,ai acheter au puce Mais j,ai regarder celle de ma soeur dans la 6 en dessus elle a un petit kaouchou noir j,ai étépour en acheter mais pas de pièce qui se vend .La compagnie en vende tu Pierrette Plourde 418-648-2816 860 rue scott Québec g1r3c9 jen ai vraiment besoin pour aimer ma caffetière attens de vos nouvelle merci beaucoup
jâttens de vos nouvelles merci
I get a message on the panel screen, that the Keurig refillable cup that was purchased with the coffee maker, was not made for this machine? I wiggle all the parts throw out my original coffee and restart the process again This usually works. The needle maintenance procedure, Will have to be tried as this morning was pretty frustrating. It is annoying to have the refillable cup called a phoney cup when it was made by Keurig.
what happens when the water wont stop pouring out. fixed the clog now water just keeps coming
Thanks Dave The fix was so simple.
I found that shoving a toothpick in the upper needle from the bottom worked for me - just try not to break off the toothpick inside the needle.
my Keurig i have had for about a year and i have cleaned the reservoir a couple of times but i have never inserted a bent paper clip in it but maybe i need to do that. But i noticed something about it just a week or two ago. when the coffee is actually coming out there is a weird kind of noise like a type of whistling and the coffee seems to be coming out a little bit slower. Usually only takes a few seconds for it to fill my cup using the large cup option. now it take about a minute for it to fill my cup..is this a sign that the needle is clogged. Any comments would be welcome.
Newer Keurigs have a Strong button. When pressed, it slows down the flow of water so the water spends more time in the coffee pod. So, yes: probably need to clean particles of coffee out of your needle. Do you like your coffee better now, or prefer it the way it was before?
