Aller au contenu principal
How to clean/replace buttons on the Skytex SP728
Ce dont vous avez besoin
  1. How to clean/replace buttons on the Skytex SP728, Case: étape 1, image 1 de 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: étape 2, image 1 de 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: étape 3, image 1 de 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: étape 4, image 1 de 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: étape 5, image 1 de 1
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: étape 6, image 1 de 1
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Chris Nelson
Membre depuis le 01/21/15
213 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 5-1, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 143
