Aller au contenu principal
How to correct left side audio only while using Bluetooth.
    • Make sure your Hesh 2 is powered on and connected to a Bluetooth source.
    • While not required, active, stereo audio playback will be very helpful, so put on some tunes.
    • Put the headphones on your head and make sure audio playback is heard in the left ear.
    • Slowly insert the Hesh 2 audio cable (3 conductor end) into the 1/8" jack on the left ear cup. You should hear the audio playback switch from left ear only to both ears but in mono only when you have bridged the left and right channel contacts. Continue to slowly insert the cable until playback stops.
    • After the playback stops, remove the cable and power cycle your Hesh 2. Reconnect to Bluetooth if required. Play some audio to verify you now have stereo audio working again.
    • If this process did not work, repeat these steps and be sure to insert the cable slowly. There must be something that happens with the Bluetooth side of the electronics when the left and right channels get bridged for more than a moment.
Ligne d'arrivée
Matt Breef
Membre depuis le 02/23/15
74 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 23
Total : 91
